Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
  • Informacja
    Dowiedz się, jak zaktualizować system do Windows 11
    Przewodnik aktualizacji do systemu Windows 11
  • Opinie
Działania
Trwa ładowanie...
HP Officejet 7610, 7612 Printers - Setting Up the Printer Hardware
This document is for the HP Officejet 7610 and 7612 Wide Format e-All-in-One printers.
This document explains how to set up the physical parts of the printer. Complete these steps before you install the printer software on your computer.
Install for a wireless or wired (Ethernet) network connection
Setting up the printer
Follow these steps in order. When you are finished, you can click the appropriate link at the end of this document if you need instructions to install the printer software.
Uwaga:
Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Step one: Check the contents of the box
Step two: Unpack the printer
Follow these steps to unpack the printer.
  1. Remove all tape and packing materials from outside the printer.
    Rys. : Remove packing materials from the outside of the printer
    Image: Remove packing materials
  2. Lift the printer scanning lid, and then remove all tape and packing materials inside.
  3. Lift the carriage access door, and then remove all tape and packing materials inside the printer.
      Przestroga:
    To avoid injury, make sure the carriage access door is fully raised before removing the tape and packing materials.
  4. Remove all tape and packing materials from the rear of the printer.
    Rys. : Remove packing materials from the rear of the printer
    Image: Remove packing materials rear
Step three: Install the printer trays
Follow these steps to install the input tray extender and output tray.
  1. Line up the input tray extender with the input tray.
  2. Push the input tray extender onto the input tray until it is seated.
    Rys. : Install the input tray extender
    Image: Install the input tray extender
  3. Place the output tray on top of the input tray extender.
  4. Push the tray inward until it snaps into place.
    Rys. : Install the output tray
    Image: Install the output tray
Step four: Connect the power cord
  1. Turn the printer to access its rear side.
  2. Connect the power cord to the rear of the printer.
  3. Plug the power cord into the power supply.
  4. Plug the other end of the power cord into an electrical outlet.
    Rys. : Connect the power cord and power supply
    Image: Connect the power cord and power supply to an electrical outlet
Step five: Turn on the printer
Adjust the display to a comfortable angle, and then press the Power button to turn on the printer.
Rys. : Adjust the display and then press the power button
Image: Adjust the display and press the power button
Step six: Load paper in the tray
Use the following steps to load paper in the input tray.
  1. Raise the output tray.
    Rys. : Raise the output tray and then pull out the input tray extender (if necessary)
    Image: Raise the ouput tray
  2. To load oversized paper, pull the input tray extender out as far as possible.
  3. Slide out the paper width guides as far as possible.
  4. Insert a stack of clean, unused, plain paper into the input tray with the short edge forward and the print side down.
      Przestroga:
    Do not load paper while the printer is printing. Jams or paper feed issues might occur.
  5. Position the stack of paper in the center of the input tray, and then slide the stack forward until it stops.
  6. Adjust the paper width guides so that they rest against the stack of paper. Do not push the guides in so tightly that they bind against the paper.
      Rys. : Load the paper, and then adjust the paper width guides
      Image: Load paper, and then adjust the paper width guides
    1. Load the paper
    2. Adjust the paper guides
  7. Lower the output tray, and then pull out the tray extender.
      Rys. : Lower the output tray, pull out the tray extender and then flip up the paper catch
      Image: Pull out the tray extender and flip up the paper catch
    1. Pull out the output tray extender
    2. Flip up the paper catch
Step seven: Set the language and country/region
Follow these steps to set the language and country/region.
  1. On the printer control panel, touch the Down Arrow () until the desired language displays.
  2. Touch the desired language, and then touch Yes to accept the language setting.
  3. Touch the Down Arrow () until the desired Country/Region displays.
  4. Touch the desired Country/Region, and then touch Yes to accept the country/region setting.
Step eight: Install the cartridges
Follow these steps to install the print cartridges.
  Przestroga:
Failure to install the SETUP cartridges that came with the printer causes a cartridge error.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Lift the carriage access door, and then open the cartridge access door.
      Rys. : Lift the carriage access door, and then open the cartridge access door
      Image: Lift carriage access door, open cartridge access door
    1. Lift the carriage access door
    2. Open the cartridge access door
  3. Remove the setup cartridge from its packaging.
  4. Hold the cartridge so that the cartridge contacts are facing toward the printer.
  5. Slide the new cartridge into its slot, and then gently push it forward until it clicks into place.
    Uwaga:
    Make sure that the colored dot on the cartridge label matches the colored dot on the slot.
    Rys. : Install the cartridge into its color-coded slot
    Image: Install cartridge in correct slot
  6. Repeat these steps for the other cartridges.
    Rys. : Install all the cartridges
    Image: Install all cartridges
  7. Close the cartridge access door, and then close the carriage access door.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj/region: Flag Polska
Działania
Trwa ładowanie...
