Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
  • Informacja
    Dowiedz się, jak zaktualizować system do Windows 11
    Przewodnik aktualizacji do systemu Windows 11
  • Opinie
Działania
Trwa ładowanie...
HP Deskjet 2020, 2029 Printers - Replacing the Ink Cartridges
This document is for HP Deskjet Ink Advantage 2020hc and DeskJet Ultra Ink Advantage 2029 printers.
This document contains steps for replacing the cartridges.
Replacing cartridges
Follow these steps to replace and align the cartridges.
Step one: Replace the cartridges
Follow these steps to replace a cartridge.
  1. Press the Power button to turn on the printer, if it is not already turned on.
  2. Open the cartridge access door.
    The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
    Rys. : Open the cartridge access door
    Image: Open the cartridge door
  3. Lightly press down on a cartridge to release it, and then pull the cartridge out to remove it from its slot.
    Rys. : Push down to release the cartridge
    Image: Push down to release cartridge
  4. On the replacement cartridge, carefully remove the plastic tape using the pink pull tab.
    Rys. : Remove the plastic tape
    Image: Removing the tape
      Przestroga:
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Rys. : Do not touch the contacts or nozzle
    Graphic:  Do not touch the contacts or nozzle.
  5. Insert the cartridge into its correct slot.
    Uwaga:
    Insert the color cartridge in the slot on the left. Insert the black cartridge in the slot on the right.
    Rys. : Insert the cartridge into its slot
    Image: Inserting a cartridge
  6. Check to make sure the cartridges sit firmly in the carriage. If a cartridge is loose, gently push inward and upward until the cartridge snaps into place.
    Rys. : Snap the cartridge into place
    Image: Snap the cartridge into place
  7. Close the cartridge access door.
    Rys. : Close the cartridge access door
    Image: Close the cartridge door
Step two: Align the cartridges
The printer's software prompts you to align the cartridges when you print a document after installing a new cartridge.
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj/region: Flag Polska
Działania
Trwa ładowanie...
