- ${title}
Trwa ładowanie...
- ${title}
Trwa ładowanie...
- ${title}
Trwa ładowanie...
- ${title}
Trwa ładowanie...
Setting Up the Printer Hardware for HP Deskjet 3050 (J610a) All-in-One Printer Series
Setting up the printer
Step one: Unpack the printer
Remove the tape and cardboard from the outside of the printer.Rys. : Remove the tape from the outside of the printer
Open the front access door, open the cartridge access door, and then remove the tape and cardboard from inside the printer.Rys. : Remove the tape and cardboard from inside the printer
Close the cartridge access door.Rys. : Close the cartridge access door
Step three: Connect the power cord and adapter
Connect the power cord to the back of the printer.Rys. : Connect the power cord into the back of the printer
Connect the power cord to the power supply, and then into a power outlet in the wall.Rys. : Connect the power cord to the power supply, and then into a power outlet in the wall
Step four: Turn on the power
Press the Power button to turn on the printer.
Rys. : Turn on the printer
Step five: Select the language and region
After turning the printer on, a list of possible language settings displays on the printer control panel. Use the following steps to set the default language and country/region for your printer.
On the printer control panel, press the button (
) next to the Down Arrow (
) to scroll through the languages, if necessary.
Press the button (
) next to OK to confirm your selection.
Press the button (
) to scroll through the regions, if necessary.
Press the button (
Rys. : Select your language and region from the printer control panel
Step six: Load plain paper
Raise the input tray.Rys. : Raise the input tray
Pull out the tray extender.Rys. : Pull out the tray extender
Slide the paper width guide to its outermost position, and then load plain, white paper into the input tray.Rys. : Slide the paper width guide outward and load paper
When prompted, press the button (
) next to OK on the printer control panel to confirm that paper is loaded in the printer.
Rys. : Press the button next to OK on the printer control panel
Step seven: Install the cartridges
Open the cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.Rys. : Open the cartridge access door
Remove the new cartridge from its packaging, and then carefully pull the pink pull tab to remove the plastic tape.
Przestroga:
Do not touch the copper-colored contacts or ink nozzles. Also, donot re-tape the cartridges. Doing so can result in clogs, ink failure, and badelectrical connections.Rys. : Remove the plastic tape -
Hold the cartridge by its sides with the nozzles toward the printer, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
The tri-color cartridge (
) goes in the slot on the left
The black cartridge (
) goes in the slot on the right
Rys. : Insert the cartridge into its slot -
Push the cartridge forward into its slot until it snaps into place.Rys. : Snap the cartridge into place
Repeat these steps to insert the other cartridge.
Press the button (
) next to OK on the printer control panel.
Rys. : Press the button next to OK on the printer control panel -
Wait about 30 seconds for the alignment page to automatically print.Rys. : The alignment page prints automatically after 30 seconds
Step eight: Align the cartridges
Lift the scanner lid.
Place the alignment page with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.Rys. : Place the alignment page on the scanner glass
Close the scanner lid.Rys. : Close the scanner lid
Press the button (
Rys. : Press the button next to OK on the printer control panelThe printer scans the alignment page and completes the alignment process.
Dodatkowe opcje wsparcia
- ${title}
Trwa ładowanie...
- ${title}
Trwa ładowanie...
- ${title}
Trwa ładowanie...
Kraj/region:
Polska
- ${title}
Trwa ładowanie...
hp-hero-support-search
- ${title}
Trwa ładowanie...
