This document applies to HP Pavilion All-in-One 200-5000 series all-in-one desktop computers.
Ostrzeżenie:Make sure the computer is disconnected from power before starting.
Przestroga:This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Step 1
To remove the hinge door, use your fingers or a flat head screwdriver to pry the cover off.
Step 2
Lift the hinge door off and away from the computer.
Step 1
Find the two small notches on the hinge door.
Step 2
Find the metal rails inside the computer.
Step 3
Align the notches on the hinge door with metal rails on the back of the computer.
Step 4
Press down until the door snaps into place.
Step 1
To remove the hard drive door, first remove the hinge door.
Step 2
Slide the hard drive door to the side.
Step 3
Pull the door off the computer.
Step 1
Find the three tabs on the hard drive door.
Step 2
Find the three slots on the back of the computer.
Step 3
Align the tabs on the door with the slots on the back of the computer.
Step 4
Slide the panel into place.
Step 5
Replace the hinge door.
Step 1
To remove the RAM door, first remove the hinge door.
Step 2
Slide the RAM door out to the side.
Step 3
Remove the door from the computer.
Step 1
Find the two tabs on the left side of the RAM door.
Step 2
On the right side of the computer, find the slots for the RAM door.
Step 3
Align the tabs on the RAM door with the slots inside the computer.
Step 4
Push in the RAM door until secure.
Step 5
Step 1
To remove the postponement door, first remove the hinge door, the hard drive door, and the RAM door.
Step 2
Remove the three screws for the postponement door.
Step 3
Lift up the bottom of the door.
Step 4
Carefully pry the cover off of the unit.
Step 1
Find the tabs at the top edge of the postponement door.
Step 2
Find the slots for the door in the top of the rear panel.
Step 3
Find the small tab on the side of the cover.
Step 4
Find the slot on the side of the computer.
Step 5
Align the tabs on the top of the door with the slots under the top lip on the computer.
Step 6
Swing the cover down.
Step 7
Press the side tab into its slot.
Step 8
Replace the three screws that secure the cover to the computer.
Step 9
Replace the hard drive door, the RAM door, and the hinge door.
Step 1
To remove the rear I/O cover, first remove the hinge door, the hard drive door, the RAM door, and the postponement door.
Step 2
Remove the two screws for the rear I/O cover.
Step 3
Lift up on the I/O cover.
Step 4
Pull the I/O cover out of the computer.
Step 1
Find the tabs on the bottom of the rear I/O cover.
Step 2
Find the slots inside the I/O area of the computer.
Step 3
To replace the rear I/O cover, slide the tabs under the lip inside the I/O area.
Step 4
Press on the cover until it snaps into place.
Step 5
Replace the postponement door, the hard drive door, the RAM door, and hinge door.
Step 1
To remove the rear cover, you must remove the stand. To remove the stand, first remove the hinge door above the stand.
Step 2
Remove the four screws that fasten the stand to the computer.
Uwaga: |
Step 3
Slide the stand up.
Step 4
Tilt the stand up and remove it from the computer.
Step 5
Remove the hard drive door, the RAM door, the postponement door, and the rear I/O cover, as shown in the other sections of this document.
Step 6
To remove the CD/DVD drive, remove the screw securing the drive to the computer.
Uwaga: |
Step 7
Use the access hole to push the CD/DVD drive out to the side.
Step 8
Pull the CD/DVD drive out of the computer.
Step 9
Remove the two screws at the top of the rear cover.
Uwaga: |
Step 10
Remove the screw at the side of the unit.
Step 11
Pry up on the top edge of the rear cover.
Step 12
Remove the cover from the computer.
Step 1
Find the tabs along the outer edge of the cover...
...that fit under the outer lip of the front bezel.
Step 2
To replace the rear cover, align the cover onto the computer.
Step 3
Press down firmly on the cover until all of the tabs have snapped into place.
Step 4
Replace the CD/DVD drive by sliding the drive into the computer.
Step 5
Align the screw hole at the edge of the drive with the screw hole inside the computer.
Step 6
Replace the special long screw that secures the CD/DVD drive in the computer.
Step 7
Replace the screw on the side of the computer.
Step 8
Replace the two screws at the top of the computer.
Step 9
Replace the rear I/O cover, the postponement door, the RAM door, and the hard drive door, as shown in the other sections of this document.
Step 10
Next, replace the stand. Find the long slot in the middle of the stand.
Step 11
Find the tab for the stand inside the computer.
Step 12
To replace the stand, align the middle slot over the tab...
... and slide the stand down until the tab is at the top edge of the slot and the stand is secure.
Step 13
Replace the four screws that secure the stand to the computer. Use the same four screws that were removed previously.
Step 14
