Follow the instructions below to load paper in the main input tray of the printer.
Przestroga:If you try to print on paper that is wrinkled, folded, or damaged in any way, a jam might occur.
Przestroga:Be aware of the paper capacities before loading.
Uwaga:When you add new paper, make sure to remove all the paper from the input tray and straighten the entire stack. This helps prevent multiple sheets of paper from feeding through the device at one time, reducing paper jams.
