Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
  • Informacja
    Windows 11
    Najczęściej zadawane pytania i odpowiedzi znajdziesz tutaj.
  • Opinie
Działania
Trwa ładowanie...
HP Photosmart C4100 Series All-in-One - Loading and Printing on 4 x 6 Inch (10 x 15 cm) Paper from the Photo Paper Cassette
This document provides instructions for loading and printing on 4 x 6 inch (10 x 15 cm) photo paper in the HP All-in-One.
Follow the steps below to load and print on 4 x 6 inch photo paper:
Load 4 x 6 inch (10 x 15 cm) paper
  1. Remove all paper from the paper tray.
  2. Using the grooves, pull out the photo paper cassette.
    Rys. : Accessing the photo paper cassette
  3. Pull the photo paper cassette towards you.
    Rys. : Pulling the photo paper cassette out
  4. Load up to 20 sheets of paper (print side down) into the photo paper cassette.
    Rys. : Loading paper into the cassette
  5. Adjust the paper-length and paper-width guides to fit the loaded paper.
    Rys. : Adjusting the paper-length and paper-width guides
  6. Line up the photo paper cassette with the right side of the input tray, then slide it into the printer until it stops.
    Rys. : Inserting the photo paper cassette into the printer
  7. Pull the tray extender out to hold the printed photos.
  8. When finished printing, remove the photo paper cassette and store it in the cassette storage area on the left side of the HP All-in-One.
    Uwaga:
    Photo paper may be stored in the stowed photo paper cassette. This protects the photo paper from rips, wrinkles, and curled or bent edges.
Print with 4 x 6 inch (10 x 15 cm) photo paper
Choose the method you want for printing and follow the appropriate steps below:
Printing from the control panel
  1. Insert a memory card into the appropriate slot on the HP All-in-One.
  2. Press View and Print.
  3. Press the right or left arrow until the photo you want to print displays on the color graphics display, then press OK.
  4. Choose 4x6, then press OK. The image preview will display.
  5. Press OK for the photo menu.
  6. Make any edits now, or choose Done Selecting and press OK.
  7. Make any additional changes here, or select Print Now to print.
Print from the HP Software
Follow the instructions below to print from either the HP Photosmart Premier or the HP Photosmart Essentials software.
Printing from HP Photosmart Premier
  1. Click the View tab and select the photos you want to print.
  2. Click the Print tab. In the Image Settings area, set the Image Size to 4x6 in.
  3. In the Printer Settings area, verify that the HP C4100 series all-in-one is selected in the Printer box. Then click the Properties button.
  4. On the Printing Shortcuts tab, select Photo Printing Borderless or Photo Printing with white borders.
  5. Click OK on the Printing Shortcuts tab to save the changes and close the Properties page.
  6. Click the Print button in Photosmart Premier to print the photo.
Printing from HP Photosmart Essentials
  2. Click the Print tab. In the Size and Quantity area, set the Image Size to 4x6 in.
  3. Click Printer Settings. Verify that the HP C4100 series all-in-one is selected in the Printer box. Set the Paper Size to 4x6 in. Then click the Advanced button.
  5. Click OK on the Printing Shortcuts tab and then click OK to close the Printer Settings.
  6. Click the Print button in Photosmart Essential to print the photo.
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj/region: Flag Polska
Działania
Trwa ładowanie...
