HP PageWide Enterprise Color 556, MFP 586 - Replace the ink-collection unit
The following information provides details about the ink-collection unit for the printer, and it includes instructions to replace it.
The printer indicates when the ink-collection unit is nearly full and when it is completely full. When it is completely full, printing stops until the ink-collection unit is replaced.
Ink-collection unit part number
B5L04-67906
Ink-collection unit
The ink-collection unit is designed for a single use. Do not attempt to empty the ink-collection unit and reuse it. Doing so could lead to pigment being spilled inside the printer, which could result in reduced print quality. After use, return the ink-collection unit to HP’s Planet Partners program for recycling.
  1. Open the left door.
  2. Remove the ink-collection unit by pulling it out with both hands. Set the unit aside, upright, on a piece of paper to prevent spills.
    When pulling out the ink-collection unit, avoid making direct contact with the black cylinder to prevent pigment smear on skin or clothes.
  3. Remove the new ink-collection unit from its packaging.
  4. Install the ink-collection unit.
  5. Close the left door.
Country/Region: Flag New Zealand
