Samsung Xpress MFP SL-M2070, SL-M2071 - Copy Features on the Control Panel
This document shows you the available copy features on the printer control panel.
Some menus may not appear in the display depending on options or models. If so, it is not applicable to your printer.
Copy features
Depending on your printer model, use one of these steps to change the menu options.
  • Press Copy > Menu > Copy Feature on the control panel.
  • Or, press Setup > Machine Setup > Default Setting > Copy Default.
  • Or press Copy, then select the menu item you want.
Item
Original Size
Sets the image size.
Reduce/Enlarge
Reduces or enlarges the size of a copied image.
If the printer is set Eco mode, reduce and enlarge features are not available.
Darkness
Adjusts the brightness level to make a copy that is easier to read, when the original contains faint markings and dark images.
Original Type
Improves the copy quality by selecting the document type for the current copy job.
Collation
Set the printer to sort the copy job. For example, if you make 2 copies of a 3-page original, one complete 3-page document will print followed by a second complete document.
  • On: Prints output in sets to match the sequence of originals.
    Figure : Collation set to On
  • Off: Prints output sorted into stacks of individual pages.
    Figure : Collation set to Off
Layout
Adjusts the layout format such as 2/4-up and ID Copy.
2-up or 4-up
Reduces the size of the original images and prints 2 or 4 pages onto one sheet of paper.
Figure : Example of 2-up or 4-up
This copy feature is available only when you load originals into the document feeder.
Adjust Background
Prints an image without its background. This copy feature removes the background color and can be helpful when copying an original containing color in the background, such as a newspaper or a catalog.
  • Off: Does not use this feature.
  • Auto: Optimizes the background.
  • Enhance Lev.1~2: The higher the number is, the more vivid the background is.
  • Erase Lev.1~4: The higher the number is, the lighter the background is.
Country/Region: Flag New Zealand
