Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
HP DeskJet, ENVY 6000, 6400 Printers - First Time Printer Setup
This document is for HP DeskJet Plus Ink Advantage 6075, 6078, 6475, 6476, 6478, ENVY 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034e, 6052, 6052e, 6055, 6055e, 6075e, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e, 6475e, ENVY Pro 6420, 6422, 6430, 6432, 6452, 6455, and 6458 All-in-One printers.
To set up a printer for the first time, unbox the printer, connect it to a power source, install HP Smart app or software, connect printer to network, load paper, install ink cartridges, and align the printer.
Remove the printer from the box, and then remove the packing material.
  1. Remove the printer and power cord from the box.
  2. Remove and recycle all packing material.
    HP DeskJet Plus Ink Advantage 6000 and HP ENVY 6000 All-in-One printers
    HP DeskJet Plus Ink Advantage 6400 and HP ENVY Pro 6400 All-in-One printers
    Removing tape from the printer
Step 2: Connect the printer to a power source
Connect the power cord to the rear of the printer, plug the other end of the power cord into an electrical outlet.
The printer turns on automatically.
Connecting the power cord
Step 3: Connect the printer
Use the HP Smart app or HP Easy Start to help you set up the printer and connect the printer to a wireless network (preferred) or USB connection.
If you do not see hardware setup instructions during app or software installation, continue to the next step. Otherwise, the setup is complete.
Step 4: Load paper and install ink cartridges
Load plain U.S. letter or A4 paper in the input tray, and then install the ink cartridges that came with your printer.
  1. Pull out the input tray.
    Pulling out the input tray
  2. Slide the paper-width guides to the edges of the input tray.
    Sliding the paper-width guides to the edges of the input tray
  3. Insert a stack of plain white paper into the input tray.
    Loading paper
    Loading paper
  4. Slide the paper-width guides in until they touch the edges of the paper. The stack of paper should slide easily against the guides.
    Sliding the paper-width guides in
  5. Close the input tray.
    Closing the input tray
  6. Lift the ink cartridge access door by using the recessed areas on the sides of the printer until it locks into place.
    The carriage moves slightly to the left.
    Opening the ink cartridge access door
  7. Wait until the carriage is idle and silent before you continue.
  8. Remove an ink cartridge from its package. Be careful to touch only the black plastic on the ink cartridge.
    Holding the ink cartridge by the sides
  9. Remove the plastic tape from the ink cartridge, and then discard or recycle the package and tape.
      forsiktig:
    Do not touch the copper-colored contacts or the ink nozzles. Handling these parts can result in clogs, ink failure, and bad electrical connections.
    Removing the plastic tape
  10. With the nozzles toward the printer, insert the ink cartridge into its slot, and then close the ink lid until the ink snaps into place.
    merknad:
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Installing the ink cartridges
  11. Repeat these steps for the other ink cartridge.
  12. Lower the ink cartridge access door, and then press gently to lock it into place.
    merknad:
    If you have not done printer alignment during app or software installation, the printer automatically prints the alignment page after 3 pages are printed. Follow the instructions on the printer alignment page to complete alignment.
Step 5: Enroll in HP Instant Ink (optional)
Your printer is eligible for HP Instant Ink, which can reduce your printing costs and save you time. After you enroll, your printer automatically monitors the printer ink levels, and then HP Instant Ink mails replacement ink cartridges when levels are low.
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
