This document is for the HP OfficeJet Pro 8210, 8216, and 8218 printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then download and install the printer software.
merknad:If you are looking for the printer software, go to http://123.hp.com/OJP8210 to download the print driver.
