Wait until the carriage stops moving before you continue.
Push in on the front of the ink cartridge to release it, and then pull the ink cartridge toward you to remove it.
Remove the replacement ink cartridge from its package.
Carefully insert the new ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
Repeat these steps for the other ink cartridges.
Make sure each ink cartridge is not sticking out farther than the other ink cartridges. If an ink cartridge is sticking out, push it until it snaps into place.
Close the ink cartridge access door.
Review the list of frequently asked questions about replacing the ink cartridges.
Which ink cartridges work with my printer?
The following table displays the ink cartridges that work with your printer.
Ink cartridge description
United States and Canada
Europe, Africa, CIS, and Middle East
Latin America
Asia Pacific and Japan
Black ink cartridge
HP 952 Black
HP 952XL Black
HP 956XL Black
HP 953 Black
HP 953XL Black
HP 957XL Black
HP 954 Black
HP 954XL Black
HP 958XL Black
HP 955 Black
HP 955XL Black
HP 959XL Black
Cyan ink cartridge
HP 952 Cyan
HP 952XL Cyan
HP 953 Cyan
HP 953XL Cyan
HP 954 Cyan
HP 954XL Cyan
HP 955 Cyan
HP 955XL Cyan
Magenta ink cartridge
HP 952 Magenta
HP 952XL Magenta
HP 953 Magenta
HP 953XL Magenta
HP 954 Magenta
HP 954XL Magenta
HP 955 Magenta
HP 955XL Magenta
Yellow ink cartridge
HP 952 Yellow
HP 952XL Yellow
HP 953 Yellow
HP 953XL Yellow
HP 954 Yellow
HP 954XL Yellow
HP 955 Yellow
HP 955XL Yellow
Where can I buy ink cartridges?
