Vennligst vent mens vi henter dine kontaktalternativer
HP kan identifisere de fleste HP-produkter og anbefale mulige løsninger.
Oppgraderingsguide til Windows 11
merknad: If your printer does not have a scanner, skip to the next step.
merknad: If you want to load legal-size paper, pull the front and rear of the tray to extend it. Figur : Extending the paper input tray
merknad: Do not overload the paper input tray. Make sure that the stack of paper fits within the tray and is no higher than the top of the guides.
merknad: If you extended the paper input tray for legal-sized paper, the tray does not sit flush with the printer body when inserted.
forsiktig: Do not connect a USB cable at this time. The printer prompts you to connect the USB during the software installation.
{{description}}
Finne serienummeret Finne produktnummeret
Logg på igjen for å fortsette
