Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
  • Opplysning
    Lær hvordan du oppgraderer til Windows 11
    Oppgraderingsguide til Windows 11
  • Tilbakemelding
Handlinger
Laster inn...
HP DeskJet 5645, ENVY 5640, 5660 Printers - Loading Paper, Envelopes, Cards, and Photo Paper
This document is for HP DeskJet Ink Advantage 5645 All-in-One, ENVY 5640, 5643, 5644, 5646, 5660, 5661, 5663, 5664, and 5665 e-All-in-One printers.
You can print on plain or specialty paper. Load paper, legal size paper, envelopes, and index cards in the printer's main input tray. Load photo paper in the photo tray. Make sure to place the printer on a hard, flat surface before you use it. Using the printer on an uneven or unsteady surface might cause the pages to print skewed, or might cause paper size adjustment issues.
  forsiktig:
Do not load any media while the printer is printing. Jams or paper feed issues might occur.
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
