Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
  • Opplysning
    Lær hvordan du oppgraderer til Windows 11
    Oppgraderingsguide til Windows 11
  • Tilbakemelding
Handlinger
Laster inn...
HP Officejet 4610 All-in-One, Officejet 4620, Deskjet Ink Advantage 4610, and Deskjet Ink Advantage 4620 e-All-in-One Printer Series - Replacing the Cartridges
This document contains steps for replacing the cartridges.
Replace the cartridges
Video of replacing the cartridges
The following video demonstrates how to replace ink cartridges.
merknad:
This video shows the HP Officejet 4620 e-All-in-One Printer series, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Replace any low or empty ink cartridges.
  1. Turn on the printer.
  2. Locate the two slots on the sides of the printer.
    Figur : Slots on the left and right sides of the printer
    Image: Slots on the left and right sides of the product
  3. Place your fingers in the slots on the right and left sides of the product, and then lift to open the ink cartridge access door.
    The carriage moves into the carriage access area.
    Figur : Open the ink cartridge access door
    Image: Open the ink cartridge access door
  4. Wait until the carriage is idle and silent before you proceed.
  5. Press the tab inward on the front of the old ink cartridge to release it, and then pull up on the ink cartridge to remove it from the slot.
    Figur : Remove the ink cartridge from its slot
    Image: Remove the ink cartridge from its slot
  6. Pull the orange pull tab straight back to remove the new ink cartridge from its packaging.
    Figur : Pull the orange tab straight back
    Image: Pull the orange tab straight back
      forsiktig:
    Make sure you remove the orange pull-tab and plastic wrap completely before you twist the orange cap in the next step. Otherwise, ink might leak from the ink cartridge. When you remove the plastic wrap, the paper label on the top of the ink cartridge tears slightly, which is necessary to properly vent the ink cartridge.
  7. Twist the protective orange cap counter-clockwise to snap it off the ink cartridge.
    Figur : Twist the orange cap to snap it off the cartridge
    Image: Twist the orange cap to snap it off the ink cartridge
  8. Hold the ink cartridge so that the ink cartridge contacts are facing toward the product.
  9. Match the colored dot on the ink cartridge with the dot of the same color on the carriage.
  10. Slide the new ink cartridge into its slot, and then gently press the ink cartridge down until it clicks into place.
    Figur : Insert the ink cartridge
    Image: Install the ink cartridge
  11. Repeat these steps for other ink cartridges, if necessary.
  12. Close the ink cartridge access door.
    Figur : Close the ink cartridge access door
    Image: Close the ink cartridge access door
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
