Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
  • Opplysning
    Lær hvordan du oppgraderer til Windows 11
    Oppgraderingsguide til Windows 11
  • Tilbakemelding
Handlinger
Laster inn...
Setting Up the Printer Hardware for HP LaserJet Pro 100 Color MFP M175a and M175nw Printer Series
  • Remove the packaging and prepare the trays
  • Load paper
  • Adjust the control panel display
  • Connect the power cord and turn on the power
  • Select the language and location
Setting up the product
Follow these steps in order.
merknad:
Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Step one: Check the contents of the box
Step two: Remove the packaging and prepare the trays
Follow these steps to remove the packaging and prepare the trays.
  1. Put the product in a sturdy, well-ventilated, dust-free place.
  2. Remove the packing tape and protective film from outside the product.
    Figur : Remove the packing tape and protective film from outside the product
    Image: Remove the packing tape and protective film from outside the product.
  3. Open the scanner assembly. The scanner assembly consists of the scanner lid and scanner bed.
    Figur : Open the scanner assembly
    Image: Open the scanner assembly.
  4. Open the print cartridge door.
    Figur : Open the print cartridge door
    Image: Open the print cartridge door.
  5. Pull out the two orange packing clips on either side of the blue packing.
    Figur : Pull out the two orange packing clips
    Image: Pull out the two orange packing clips.
  6. Pull the orange tab to remove the blue plastic packing.
    Figur : Pull the orange tab to remove the blue plastic packing
    Image: Pull the orange tab to remove the blue plastic packing.
  7. Remove the instruction sheet, if one is in the product.
    Figur : Remove the instruction sheet
    Image: Remove the instruction sheet.
  8. Close the print cartridge door, and then open the output tray and flip up the output tray extender.
    Figur : Close the print cartridge door, and then open the output tray and extender
    Image: Close the print cartridge door, and then open the output tray and extender.
  9. Close the scanner assembly, and then pull out the input tray.
    Figur : Close the scanner assembly, and then pull out the input tray
    Image: Close the scanner assembly, and then pull out the input tray.
  10. Remove the input tray from its packaging, and then flip the tray.
    Figur : Remove the input tray from its packaging and flip the tray
    Image: Remove the input tray from its packaging  flip the tray.
  11. Insert the input tray into the product. Make sure that it snaps into place.
    Figur : Insert the input tray
    Image: Insert the input tray into the product.
  12. Recycle the packing materials.
    Figur : Recycle the packing materials
    Image: Recycle the packing materials.
Step three: Load paper
  1. Slide the paper width and length guides to their outermost positions. To slide out the paper width guides, use the grey tab on the right-hand guide.
  2. Load the paper in the input tray, print side up. Slide the paper forward until it stops.
    merknad:
    Do not overload the tray. Make sure that the stack of paper fits within the tray and is no higher than the top of the guides.
    Figur : Load the paper
    Image: Load the paper.
  3. Slide the paper width and length guides inward until they stop at the edges of the paper.
    Figur : Slide paper guides inward
    Image: Slide paper guides inward.
Step four: Adjust the control panel display
Squeeze the latch behind the control panel display. Gently lift the display into the preferred position, and then release the latch. Make sure that the display clicks into place.
Figur : Adjust the control panel display
Image: Adjust the control panel display.
Step five: Connect the power cord and turn on the power
  1. Connect the power cord to the back of the product.
    Figur : Connect the power cord
    Image: Connect the power cord.
  2. Plug the power cord into the electrical outlet.
  3. Press the Power button () to turn on the product. The product initializes and calibrates itself. Wait until the product is idle and silent before proceeding. Do not connect the USB cable yet.
    Figur : Press the power button
    Image: Press the power button.
    Figur : Do not connect the USB cable yet
    Image: Do not connect the USB cable yet.
Step six: Select language and location
Follow these steps to select the language and location on the product control panel.
Figur : Product control panel
Image: Product control panel.
  1. On the control panel, press the Right Arrow button () to select the preferred language, and then press OK.
    merknad:
    If you select the wrong language, press the Right Arrow button () to select No, and then press OK.
  2. Press OK again to confirm the selection.
  3. Press the Right Arrow button () to select the location, and then press OK.
  4. Press OK again to confirm the selection.
    The product calibrates itself. Wait until the control panel displays 'Ready' before proceeding.
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
