Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
HP Photosmart Premium C309a and C309c All-in-One Printers - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Adjust the control panel display
  • Install the document feeder tray
  • Install the control panel faceplate
  • Connect the power cord and adapter
  • Connect the phone cord
  • Turn the product on
  • Install the cartridges
  • Load paper
  • Align the cartridges
Follow these steps in order.
  1. Remove all tape and packing materials from the outside of the product.
  2. Use the access handles on the sides of the product to open the cartridge door, and then remove the tape and the cardboard restraint from inside the product.
    Figur : Open the cartridge door and remove tape and cardboard restraint
  3. Close the cartridge door.
    Figur : Close the cartridge door
Step two: Adjust the control panel display
Adjust the control panel display, and then remove its protective film.
Step three: Install the document feeder tray
Line up the tabs of the document feeder tray with the slots on the product, and then insert the tabs into the slots until they snap into place.
Figur : Insert the document feeder tray
Step four: Install the control panel faceplate
  1. Positon the faceplate over the buttons on the product, and then press down firmly on all edges of the faceplate until it snaps into place.
    Figur : Install the control panel faceplate
  2. Make sure all buttons are visible and not blocked.
merknad:
If you need to remove the control panel faceplate, pull up on the right edge of the faceplate.
Step five: Connect the power cord and adapter
  1. Plug the adapter into the back of the product.
  2. Plug the power cord into the power adapter.
  3. Plug the other end of the power cord into an electrical outlet.
      Figur : Connect the power cord and adapter
    1. Plug the adapter into the product
    2. Plug the power cord into the adapter
Step six: Connect the phone cord
Connect one end of the supplied phone cord to the port labeled 1-LINE on the back of the product, and then connect the other end to a telephone jack.
Figur : Connect the phone cord
Step seven: Turn the product on
  1. Press the Power button () to turn the product on.
    Figur : Press the power button
  2. If a prompt displays on the control panel display, press the arrow buttons to select your language, and then press OK to confirm the selection.
    Figur : Press arrow buttons to select your language
  3. Press the arrow buttons to select your country/region, and then press OK to confirm the selection.
Step eight: Install the cartridges
  1. Use the access handles on the sides of the product to open the cartridge door.
  2. Remove the orange plastic carriage restraint and discard or recycle it.
    Figur : Remove the orange plastic carriage restraint
  3. On the new cartridge, pull the orange pull-tab to remove the plastic wrap.
    Figur : Remove the plastic wrap
  4. Twist the orange cap counterclockwise to snap it off.
    Figur : Remove the orange cap
    merknad:
    The orange cap might seem difficult to remove. If so, firmly twist the cap.
  5. Slide the new cartridge into its empty slot until it clicks into place and is seated firmly in the slot. Make sure that you insert the cartridge into the slot that has the same shape icon and color.
    Figur : Insert the cartridge
  6. Press down on the cartridge until it clicks firmly into place.
    Figur : Press the cartridge into place
  7. Repeat these steps to install the other cartridges.
    Figur : Repeat steps to install other cartridges
  8. Close the cartridge door.
Step nine: Load paper
  1. Lift the output tray.
    Figur : Lift the output tray
  2. Slide the paper-width guide to the left.
    Figur : Slide paper-width guide left
  3. Load a stack of plain white paper into the input tray, and then slide the paper-width guide in to the edge of the paper.
    Figur : Load plain paper and slide paper guide in
  4. Lower the output tray.
    Figur : Lower output tray
Step ten: Align the cartridges
  1. Press OK, and then wait while the product prints an alignment page.
  2. After the alignment page is printed, press OK. Discard or recycle the alignment page.
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
