Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
HP Photosmart D7345, D7355, D7360, D7363, and D7368 Printers - Install the Ink Cartridges
This document explains how to install new ink cartridges or replace empty ink cartridges.
Install ink cartridges
Follow the steps below to insert or replace the ink cartridges.
  1. Make sure the power is on, then lift the top cover. Make sure all packing material has been removed from inside the printer.
    Figur : Top cover open
  2. Squeeze the gray tab below an ink cartridge slot to release the gray latch inside the printer, then lift the latch. The ink cartridge areas are color-coded for easy reference. Lift the latch below the appropriate color to insert or replace a cartridge. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
      Figur : Ink cartridge slots
    1. Ink cartridge latch for the black ink cartridge
    2. Ink cartridge area for the color ink cartridges
  3. If you are replacing a cartridge, remove the old cartridge by pulling it toward you out of its slot.
    Figur : Ink cartridge removal
    Recycle the old cartridge. The HP Inkjet Supplies Recycling Program is available in many countries/regions and lets you recycle used ink cartridges free of charge. For more information about recycling, click here to go to www.hp.com/go/recycle.
  4. Remove the new ink cartridge from its packaging, and while holding it by the handle, slide the ink cartridge into the empty slot. Make sure you insert the ink cartridge into the slot that has the same shaped icon and color as the new cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
    merknad:
    The first time you set up and use your HP Photosmart printer printer, make sure to install the ink cartridges that were shipped with your printer. The ink in these ink cartridges is specially formulated to mix with the ink in the print head assembly.
  5. Press down on the gray latch until it clicks into place.
    Figur : Ink cartridge latch closed
  6. Repeat steps 2 through 5 for each ink cartridge you are replacing. You must install all six cartridges. The printer will not work if an ink cartridge is missing.
  7. Close the top cover. The touch screen displays six ink drop icons showing the approximate ink level for each cartridge when low ink levels are detected.
    Figur : Ink levels
    merknad:
    If you are using non-HP ink, a question mark appears instead of the ink drop in the icon for that cartridge. The printer cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink.
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
