Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
HP Photosmart C4100 Series All-in-One - Installing Print Cartridges
This document contains information about installing the print cartridges.
Installing the print cartridges
merknad:
The HP All-in-One must be powered on before you can insert the printcartridge.
  1. Place the unit flat on a level surface.
  2. Open the print cartridge door by lowering it until it stops. The print carriage moves to the far right side of the HP All-in-One.
    Figur : Print cartridge door and print carriage
  3. Pull the pink tab to remove the tape from the print cartridge.
    Figur : Removing the pink tab
      forsiktig:
    Donot touch or remove the ink nozzles orcopper-colored contacts, or re-tape thecartridges.
    Figur : Do not touch ink nozzles or copper-colored contacts
  4. Insert each print cartridge as follows:
    merknad:
    • Insert the tri-color print cartridge in the slot on the left side, marked with a green label.
    • Insert the black (or photo) print cartridge in the slot on the right side, marked with a black and orange label.
    1. Hold the print cartridge with the HP label facingup.
    2. Push the print cartridge firmly into the corresponding slot until it snaps intoplace.
      Figur : Inserting the print cartridge
      Figur : Print cartridges properly installed
  5. Close the access door.
    Figur : Access door being closed
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
