Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
  • Opplysning
    Windows 11
    Du finner vanlige spørsmål og svar her.
  • Tilbakemelding
Handlinger
Laster inn...
HP PSC 1310 Series - Installing Cartridges
merknad:
Install the cartridges as soon as possible after you remove the tape. Remove only the tape! Do not attempt to remove the copper strip.
Figur : If you have a new print cartridge, remove the tape
Figur : Make sure the printer is turned on
Figur : Open both doors on the printer, then wait a moment for the cartridge carriage to come to the center
Figur : Place the tri-color cartridge in the left slot at a slight angle, then press up and forward until the cartridge snaps into position
Figur : Place the black or photo cartridge in the right slot at a slight angle, then press up and forward until the cartridge snaps into position
Figur : Close the gray door
Handlinger
Laster inn...
Handlinger
Laster inn...
Handlinger
Laster inn...
Land/område: Flag Norge
Handlinger
Laster inn...
