    Check documents and videos on compatibility, FAQs, upgrade information and available fixes. Windows 11 Support Center
HP PageWide Pro 750, MFP 772, 777 - Connect the product to a computer or a network
To connect the product using a USB cable
You can use a USB cable to connect the product to a computer.
This product supports a USB 2.0 connection. Use an A-to-B type USB cable. HP recommends using a cable that is no longer than 2 m.
Do not connect the USB cable until the installation software prompts you to connect it.
  1. Quit all open programs on the computer.
  2. Install the printer software from HP Customer Support, and follow the onscreen instructions.
  3. When prompted, select USB-Connect the printer to the computer using a USB cable, and then click the Next button.
    A dialog box displays a warning that HP ePrint and print Apps are unavailable with a USB installation. Click Yes to proceed with the USB installation, or click No to cancel it.
  4. When the software prompts you, connect the Type B end of the USB cable to the USB Type B connection port (1) at the rear of the product.
  5. When the installation is complete, print a page from any program to make sure that the printing software is correctly installed.
To connect the product to a network
The product supports connection to either a wired or a wireless network.
Supported network protocols
The product supports the following network protocols:
  • AirPrint 1.6 x
  • AirPrint Scan
  • ARP Ping
  • Bonjour
  • Bootp
  • CIFS client
  • DHCP, AutoIP
  • DHCP v6
  • HTTP, HTTPS
  • IPP
  • IPv4
  • IPv6
  • Legacy Default IP
  • LLMNR
  • LPD
  • Microsoft Web Services (Print, Scan, Discovery)
  • Netbios
  • Port 9100 Printing
  • SLP
  • SMTP client for alerts
  • SNMP V1, V2, V3
  • Syslog
  • TLS 1.0, 1.1, 1.2
  • WINS
  • WPA Enterprise
Connect the product using a wired network
Use this procedure to install the product on a wired network:
  1. Connect the Ethernet cable to the Ethernet port (1) and to the network.
  2. Turn the product on.
  3. Wait for 60 seconds before continuing. During this time, the network recognizes the product and assigns an IP address or host name for the product.
  4. Open the control panel dashboard (swipe the dashboard tab at the top of any screen downward, or touch the strip at the top of the home screen).
  5. On the control panel dashboard, touch (Ethernet) to display the IP address. Touch Print Details to print a page with the IP address.
Connect the product using a wireless network (wireless models only)
The wireless capability is off, by default. Use the following methods to turn wireless on and connect the product to a wireless network:
The printer supports 802.11n networks (2.4GHz and 5GHz).
If your wireless router does not support Wi-Fi Protected Setup (WPS), ask your system administrator for the wireless network name or service set identifier (SSID) and the wireless network security password or encryption key.
To enable wireless capability on the product
  1. Open the control panel dashboard (swipe the dashboard tab at the top of any screen downward, or touch the strip at the top of the home screen).
  2. On the control panel dashboard, touch (Setup).
  3. Touch Network Setup, and then touch Wireless Settings.
  4. Touch Wireless and select On.
To connect the product to a wireless network using the Wireless Setup Wizard
The Wireless Setup Wizard is the best method for installing the product on a wireless network.
  1. Make sure the wireless capability for your printer is turned on.
  2. Open the control panel dashboard (swipe the dashboard tab at the top of any screen downward, or touch the strip at the top of the home screen).
  3. On the control panel dashboard, touch (Setup).
  4. Touch Network Setup, and then touch Wireless Settings.
  5. Touch Wireless Setup Wizard.
  6. The product scans for available wireless networks and returns a list of network names (SSIDs). Select the SSID for your wireless router from the list if it is available. If the SSID for your wireless router is not in the list, touch Enter SSID. When prompted for the type of network security, select the option that your wireless router uses. A keypad opens on the control panel display.
  7. Do one of the following:
    • If your wireless router uses WPA security, type the passphrase on the keypad.
    • If your wireless router uses WEP security, type the key on the keypad.
  8. Touch OK, and wait while the product establishes a connection with the wireless router. Establishing the wireless connection can take a few minutes.
To connect the product to a wireless network using WPS
Before you can connect your printer to a wireless network using WPS, make sure you have the following:
  • A WPS-enabled wireless router or access point.
  • A computer connected to the wireless network that you intend to connect the printer to. Be sure you have installed the HP printer software on the computer.
If you have a WPS router with a WPS push button, follow the Push Button method. If you are not certain your router has a push button, follow the PIN method.
Push Button method
  5. Touch Wi-Fi Protected Setup and select Push Button.
  6. Touch Start.
PIN method
  2. Locate the WPS PIN:
    4. Touch Wi-Fi Protected Setup, and then touch PIN.
    The WPS PIN displays onscreen.
  3. Open the configuration utility or software for the wireless router or wireless access point, and then enter the WPS PIN.
    For more information about using the configuration utility, see the documentation provided with the router or wireless access point.
  4. Wait for about two minutes. If the printer connects successfully, the (Wireless) indicator stops blinking but remains lit.
To connect the product to a wireless network manually
During the first 120 minutes of product setup, or after resetting the product's network defaults (and without a network cable attached to the product), the product's wireless radio will broadcast a wireless setup network for the product.
The name of this network is “HP-Setup-xx-[product name]”.
The “xx” in the network name is the last two characters of the product's MAC address. The product name is HP PageWide Pro MFP 772-777.
  2. From a wireless enabled product, connect to the setup network for the device.
  3. Open a web browser while connected to this setup network, and open the HP Embedded Web Server (EWS) using the following IP address.
    • 192.168.223.1
  4. Find the Wireless Setup Wizard in the EWS and follow the instructions to manually connect the product.
    The product provides an Automatic DHCP address by default.
Country/Region: Flag Lithuania
