    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP Chromebook x360 - 14c-ca0065nr Product Specifications
2Z777UA
Intel® Pentium® Gold 6405U (2.4 GHz base frequency, 2 MB L3 cache, 2 cores)
4 GB DDR4-2400 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics
  • Integrated
  • 64 GB eMMC
  • [14]
Optical drive
Optical drive not included
14" diagonal FHD, IPS, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.57 x 21.85 x 1.78 cm
1.64 kg
45 W USB Type-C™ power adapter
3-cell, 60.9 Wh Li-ion
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
Pre-installed software
Biometric Fingerprint Reader; Google Play Store; Google Assistant
Country/Region: Caribbean
