Features
Dimensions (HxWxD)
Starting at 5.0 lb (2.27 kg)
note: |
Stand-Alone Power
Requirements (AC Power)
Temperature
Operating:
Non-operating: –4 degree to 140 degree F (–20 degree to 60 degree C)
Relative Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6 degree F (38.7 degree C) maximum wet
bulb temperature
Shock
Operating: 125 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude
(unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m)
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m)
- ${title}
- ${title}
- ${title}
- ${title}
HP 541 Notebook PC - Specifications
Hardware Specifications
Communications
Features
HP Integrated Module with Bluetooth Wireless Technology
V.92 56K Data/Fax Modem
Form Factor MDC: 1.5 Daughtercard
Power Management
Support: APM Revision 1.2, ACPI
Audio
Features
Audio
Power
Features
Power Conservation
Wireless Devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
Intel Wireless WiFi Link 4965AGN*
Integrated support for 802.11a, b, g, and draft-n
Up to 243 mbps data rate
Intel Wireless WiFi Link 4965AG*
Integrated support for 802.11 a, b and g
Up to 54 mbps data rate
Intel PRO/Wireless 3945ABG Network Connection*
Intel PRO/Wireless 3945BG Network Connection*
Integrated support for 802.11 b and g
Broadcom 4311AGN 802.11a/b/g/draft n
WiFi Adapter
Broadcom 4311BG 802.11b/g
WiFi Adapter
Bluetooth Specification v2.0 compliant
Works with a wide range of Bluetooth devices
note: |
Expansion card slots
Features
ExpressCard/54 slot
Link to product overview
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Caribbean
- ${title}
hp-hero-support-search
- ${title}
