HP LaserJet M5025 and M5035 MFP Series - Install Printer Memory
It may be desired to add more printer memory to the printer if often complex graphics, PostScript (PS) documents are printed, or many downloaded fonts are used. Added memory also gives more flexibility in supporting job-storage features, such as quick copying.
Installing printer memory
Static electricity can damage DIMMs. When handling DIMMs, either wear an antistatic wrist strap or frequently touch the surface of the DIMM antistatic package, then touch bare metal on the printer.
The HP LaserJet M5025 MFP and HP LaserJet M5035 Series MFP MFPs come with one DIMM slot. If desired, a DIMM installed in the slot can be replaced with a higher memory DIMM.
If it has not already been done, print a configuration page to find out how much memory is installed in the printer before adding more memory. Click here for more information on Using information pages at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00766488.
  1. Turn Off the device, and disconnect all the cables as shown in the figure below.
    Figure : Disconnecting the cables
  2. At the back of the device, remove the formatter cover.
    Figure : Removing the formatter cover
  3. Open the formatter door.
    Figure : opening formatter door
  4. Remove the DIMM from the antistatic package.
    Figure : Removing the DIMM
    To reduce the possibility of damage caused by static electricity, always wear an electrostatic discharge (ESD) wrist strap or touch the surface of the antistatic package before handling DIMMs.
    Figure : Holding the DIMM by edges
  5. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot. (Check that the locks on each side of the DIMM slot are open.)
    Figure : DIMM slot
  6. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
    Figure : Locks on each side of DIMM
    To remove a DIMM, first release the locks.
  7. Close the formatter door.
    Figure : Replacing formatter door
  8. Replace the formatter cover.
    Figure : Closing formatter door
  9. Reconnect the cables as shown in the figure below, and then turn On the device.
    Figure : Reconnecting cables
Country: Caribbean
