조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP Laser 100 Printers - Replacing the Toner Cartridge
This document is for HP Laser 103a, 107a, 107r, 107w, 108a, and 108w printers.
Replace the toner cartridge if it is low or empty.
To replace the toner cartridge, open the top cover, remove the old toner cartridge, and then install a new one.
  1. Open the top cover.
    Opening the top cover
  2. Grasp the handle on the toner cartridge, and then pull the toner cartridge out to remove it.
    Removing the toner cartridge
  3. Remove the new toner cartridge from its package, and then discard or recycle the packing materials.
    Removing the packaging from the toner cartridge
  4. Grasp both sides of the toner cartridge, and then distribute the toner by gently rocking the toner cartridge back and forth.
    Rocking the toner cartridge back and forth
  5. Align the new toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
    Inserting the new toner cartridge into the printer
  6. Close the top cover.
    Closing the top cover
Review the list of frequently asked questions about replacing toner cartridges.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
