조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP Laser 100 Printers - Loading Paper, Envelopes
This document is for HP Laser 103a, 107a, 107r, 107w, 108a, and 108w printers.
Load paper or envelopes into the input tray.
Load plain paper
Load a stack of paper into the input tray.
  1. Open the paper tray.
    Opening the paper tray
  2. Slide out the paper-width guides as far as possible.
    Sliding out the paper-width guides
  3. Load paper into the tray print side up with the top edge towards the printer. To prevent paper jams, make sure the stack is below the paper fill guide.
    Loading paper into the input tray
  4. Slide in the paper-width guides until they touch the edge of the stack of paper.
    Adjusting the paper guide to the slides of the paper
Your printer is now ready to print. Before printing, make sure to select the correct paper size and settings from the computer.
Load envelopes
Load a stack of envelopes in the input tray.
  3. Load envelopes into the input tray.
    Orientation of envelope types
  4. Slide in the paper-width guides until they touch the edge of the stack of envelopes.
    Adjusting the paper-width guides to the sides of the envelopes
Your printer is now ready to print on envelopes or photo paper. Before printing, make sure to select the correct paper size and settings from the computer.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
