조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
    HP 공식 카카오톡 채널 사칭 피해 주의 안내
    HP 공식 카카오톡 채널 구분 방법 확인
    정보
    Windows 11로 업그레이드하는 방법 알아보기
    Windows 11 업그레이드 설명서
  • 피드백
조치
로드 중...
HP Laser MFP 130, 1000 Printers - Loading Paper, Envelopes
This document is for HP Laser MFP 131a, 133pn, 135a, 135ag, 135r, 135w, 135wg, 136a, 136nw, 136w, 137fnw, 137fwg, 138fnw, 138p, 138pn, 138pnw, 1136w, 1139a, 1188a, 1188w, 1188nw, and 1188pnw printers.
Learn how to properly load paper or envelopes into the input tray.
Load plain paper
Load a stack of paper into the input tray.
  1. Open the input tray.
    Opening the input tray
  2. Slide out the paper guide as far as possible.
    Sliding out the paper guide   as far as possible
  3. Load paper into the tray print side up with the top edge towards the printer. To prevent paper jams, make sure the stack is below the paper fill guide.
    Loading paper into the tray print side up
  4. Slide in the paper guide until it touches the edge of the stack of paper.
    Sliding in the paper guide until it touches the paper
주의:
Before printing or copying, select the correct paper size and type settings from the control panel or computer.
Load envelopes
Load a stack of envelopes in the input tray.
  3. Load envelopes into the input tray. To prevent paper jams, make sure the stack is below the paper fill guide.
    Example orientation for different types of envelopes
  4. Slide in the paper guide until it touches the edge of the stack of envelopes.
주의:
Before printing on the envelopes, select the correct envelope size and settings from the control panel or computer.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
