조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
    Windows 11로 업그레이드하는 방법 알아보기
    Windows 11 업그레이드 설명서
    정보
  • 피드백
조치
로드 중...
Securely Reporting a Product Security Vulnerability
PGP can be used to verify the authenticity of a message received and/or encrypt a message at rest before it is sent.
You can use the HP Product Security Response Team’s (PSRT) PGP key below to encrypt a message containing sensitive information before sending to HP’s security inbox, hp-security-alert@hp.com.
Key-ID: 08F8DDD9
Fingerprint: E28D 172B 46A9 3928 7A7E 9B2C F46E CE7D 08F8 DDD9
Key Type: RSA
Key Length: 4096
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v2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=J7DE
-----END PGP PUBLIC KEY BLOCK-----
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
