조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP LaserJet M26 Printers - First Time Printer Setup
This document is for HP LaserJet Pro MFP M26a and 26nw printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, load paper into the input tray, connect the power cable, set control panel preferences, and then download and install the printer software.
주의:
If you are looking for the printer software, go to http://123.hp.com/laserjet.
Step 1: Remove the printer from the box and prepare the cartridge
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer, and then remove the film from the printer control panel.
  3. Open the scanner assembly, and then open the top cover.
    사진 : Opening the scanner assembly, and then opening the top cover
    Opening the scanner assembly, and then opening the top cover.
  4. Remove the protective foam from the toner cartridge access area.
    사진 : Removing the protective foam
    Removing the protective foam.
  5. Remove the toner cartridge, and then set it aside in a secure place.
    사진 : Removing the toner cartridge
    Removing the toner cartridge.
  6. Remove packaging from inside the printer.
    사진 : Removing packaging from inside the printer
    Removing packaging from inside the printer.
  7. Grasp both sides of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    사진 : Gently rocking toner cartridge
    Gently rocking toner cartridge.
  8. Remove the orange clip from the toner cartridge.
    사진 : Remove the orange clip from the toner cartridge
    Remove the orange plastic clip from the toner cartridge.
  9. Pull the orange tab to remove the sealing tape from the toner cartridge.
    사진 : Remove the sealing tape from the toner cartridge
  10. Align the toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
    사진 : Insert the toner cartridge
    Insert the toner cartridge.
  11. Close the top cover, and then close the scanner assembly.
    사진 : Closing the scanner assembly
  12. Recycle the packing materials.
Step 2: Load plain paper in the input tray
Load plain U.S. letter or A4 paper in the input tray.
  1. Push in the input tray until it snaps into place.
    사진 : Attaching the input tray to the printer
    Attaching the input tray to the printer.
  2. Slide the paper guides to their outermost positions.
    사진 : Sliding out the paper guides
    Sliding out the paper guides.
  3. Load a stack of U.S. letter or A4 size paper into the input tray with the short edge forward and the print side up. Push the stack into the tray until it stops.
    사진 : Loading paper into the input tray
    Loading paper into the input tray.
  4. Slide in the paper guides until they rest against the edges of the paper.
    주의:
    Do not push the paper guides so far in that they bind the paper.
    사진 : Sliding in the paper guides
    Sliding in the paper guides.
Step 3: Connect the power cord, and then turn on the printer
Plug the printer into a wall outlet, and then turn on the printer.
    사진 : Connecting the power cord
    Connecting the power cord.
  2. Turn on the printer.
Step 4: Set your language preference (printers with a 2-line display )
Set the language preference for your printer. Skip to the step to install the printer software if your printer does not have a 2-line display.
  1. On the printer control panel, press the Setup button .
  2. Press the right arrow until System Setup displays, and then press OK.
  3. Select Language, and then press OK.
  4. If necessary, press the right arrow to find the desired language in the list.
  5. Select your desired language, and then press OK.
Step 5: Install the printer software
Download the latest version of the printing software from 123.hp.com/laserjet, and then follow the on-screen instructions to install the software.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
