This document is for the following printers:
HP DeskJet Ink Advantage 4535, 4536, 4538, 4675, 4676, and 4678 All-in-One printers
HP ENVY 4510 (series), 4511, 4512, 4513, 4516, 4520, 4521, 4522, 4523, 4524, 4525, 4526, 4527, and 4528 All-in-One printers
HP OfficeJet 4650, 4652, 4654, 4655, 4656, 4657, and 4658 All-in-One printers
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then install the software.
주의:If you are looking for the printer software, go to 123.hp.com, type your printer model number, click Begin, and then click Download.
