조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
    Windows 11
    일반적인 질문 및 답변을 여기에서 찾아보세요.
    정보
  • 피드백
조치
로드 중...
HP LaserJet Pro Printers - Setting Up the Printer Hardware
This document is for HP LaserJet Pro MFP M125a, M125nw, M125r, M125rnw, M126a, M126nw printers.
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Step 2: Remove the packaging and prepare the cartridge
Follow these steps to remove all the packaging material from the printer and then prepare the cartridge for printing.
  1. Take the printer out of its box, and then remove the packaging.
    사진 : Unpack the printer
    Image: Unpack the printer
  2. Put the printer on a sturdy table in a well-ventilated, dust-free place, away from direct sunlight.
  3. Remove the packing tape from the printer.
    사진 : Remove the packing tape from the printer
    Image: Remove the packing tape from the printer.
  4. Open the scanner assembly, and then open the top cover.
    사진 : Open the scanner assembly, and then open the top cover
    Image: Open the scanner assembly, and then the top cover.
  5. Remove the protective foam from the cartridge access area, and then set it aside for recycling.
    사진 : Remove the protective foam
    Image: Remove the protective foam.
  6. Remove the toner cartridge, and then set it aside in a secure place.
    사진 : Remove the toner cartridge
    Image: Remove the toner cartridge, and set it aside in a secure place.
  7. Remove packaging from inside the printer, and then set it aside for recycling.
    사진 : Remove packaging from inside the printer
    Image: Remove packaging from inside the printer.
  8. Grasp both sides of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    사진 : Gently rock toner cartridge
    Gently rock toner cartridge.
  9. Remove the orange clip from the toner cartridge, and then set it aside for recycling.
    사진 : Remove the orange clip from the toner cartridge
    Image: Remove the orange plastic clip from the toner cartridge.
  10. Pull the orange tab to remove the sealing tape from the toner cartridge, and then set it aside for recycling.
    사진 : Remove the sealing tape from the toner cartridge
    Image: Pull the orange tab to remove the sealing tape from the toner cartridge.
  11. Align the toner cartridge with the tracks inside the printer, and then insert the toner cartridge until it is firmly seated.
    사진 : Insert the print cartridge
    Image: Insert the print cartridge.
  12. Close the top cover, and then close the scanner assembly.
Step 3: Load paper
Follow these steps to load paper in the paper input tray.
  1. Attach the input paper tray to the printer.
    사진 : Attach the input paper tray to the printer
    Image: Attach the  input paper tray to the printer.
  2. Slide the paper guides to their outermost positions.
    사진 : Slide the paper guides out
    Image: Slide the paper guides out
  3. Load a stack of U.S. letter or A4 size paper into the input tray with the short edge forward and the print side up. Push the stack into the tray until it stops.
    사진 : Load paper into the input tray
    Image: Load paper into the input tray.
  4. Slide in the paper guides until they rest against the edges of the paper.
    주의:
    Do not push the paper guides so far in that they bind the paper.
    사진 : Slide the paper guides in
    Image: Slide the paper guides in.
Step 4: Connect the power cord and turn on the power
  1. Connect the power cord to the rear of the printer.
  2. Plug the power cord into an electrical outlet.
    사진 : Connect the power cord
    Image: Connect the power cord.
  3. Press the Power button to turn on the printer. The printer initializes and calibrates itself.
    주의:
    Wait until the printer is idle and silent before proceeding.
Step 5: Select the language
Follow these steps to select the language displayed on the printer control panel.
  1. On the printer's control panel, press the Setup () button.
  2. Press the Right Arrow () until System Setup displays, and then press OK.
  3. Touch Language, and then if necessary, press the Right Arrow () to find your desired language in the list.
  4. Touch your desired language.
    주의:
    If you selected the wrong language, repeat these steps.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
