조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
Setting Up the Printer Hardware for the HP Photosmart C4700 All-in-One Printer Series
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Select the language/region
  • Install the cartridges
  • Load plain paper
  • Align the cartridges
Setting up the All-in-One
Follow these steps in order.
  1. Lower both the paper tray and the cartridge door.
    사진 : Lower the paper tray
  2. Remove all packing material and protective film from the product.
    사진 : Remove the packing material
  3. Close the cartridge door.
    사진 : Close cartridge door
Step three: Connect the power cord and adapter
주의:
Do not connect the USB cable.
  1. Connect the power adapter to the back of the product.
  2. Connect the power cord to the power adapter.
  3. Connect the other end of the power cord to an alternating current (AC) power outlet.
사진 : Connect the power cord and adapter
Step four: Turn on power
Press the Power button () to turn on the product.
사진 : Press Power
Step five: Select the language/region
Follow the instructions on the control panel display to set the default language and country/region for the product.
  1. Press the colored buttons to the left of the display to select the up arrow () or down arrow () icons on the display until your language is selected.
  2. Press OK to confirm.
  3. Press the colored buttons to the left of the display to select the up arrow () or down arrow () icons on the display until your country/region is selected.
  4. Press OK to confirm.
Step six: Install the cartridges
Leave the product turned on and follow these steps to install the cartridges.
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off, and then turn it back on again.
    사진 : Open the cartridge door
  2. Remove the cartridges from their packaging, and then remove the pink protective tape from both cartridges.
      경고:
    Do not touch the copper-colored contacts or re-tape the cartridges.
    사진 : Remove the pink tape
    사진 : Do not touch contacts
  3. Hold the cartridges with the label on top.
    사진 : label on top
  4. Insert the tri-color cartridge into the left carriage slot and insert the black cartridge into the right carriage slot.
    사진 : Tri-color cartridge in the left slot
  5. Press the cartridges firmly into the carriage until they snap into place.
    사진 : Insert cartridges until they snap into place
  6. Close the cartridge door.
  7. Press OK to confirm the installation of genuine HP cartridges, when prompted.
Step seven: Load plain paper
  1. Pull out the tray extender, and then flip open the paper catch.
    사진 : Pull out tray extender
  2. Load paper in the input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
    사진 : Load paper
    주의:
    Make sure all the paper in the stack is the same size and type and free from rips, dust, wrinkles, and curled or bent edges.
  3. Slide the paper-width guide inward until it stops at the edge of the paper.
  4. Press OK.
Step eight: Align the cartridges
When you install a new cartridge, the product aligns the cartridges. You can also align the cartridges at any time using the product software. Aligning the cartridges helps produce high quality output.
  1. Follow the instructions on the control panel display to print the alignment page.
    사진 : Alignment page prints
  2. Lift the lid.
  3. Load the alignment page face down in the front right corner of the glass.
    사진 : Load alignment page
  4. Close the lid, and then press OK to complete the alignment.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
