조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP Officejet J5700 Series All-in-Ones - Installing Cartridges
This document provides information on how to install cartridges in Officejet J5700 Series All-in-Ones.
Installing cartridges
Before you begin, make sure to check the cartridge compatibility for your product.
Step one: Install the cartridges
Follow these instructions to install the cartridges:
  1. Press the On button to turn on the product.
    주의:
    The On button is lit when the product is turned on.
    사진 : Pressing the ON button
  2. Open the carriage access door by lifting it, and then wait until the carriage moves to the far right side and the product becomes idle and silent.
    사진 : Lifting up the carriage access door
  3. Remove the protective tape from the new, compatible cartridge.
    주의:
    You can use the link provided at the top of this article to check cartridge compatibility for your product, and to order new cartridges.
      경고:
    When removing the protective tape, do not attempt to remove the copper strip.
      사진 : Removing the protective tape
    1. Protective tape
      경고:
    After the tape is removed, do not touch the copper contacts or the ink nozzles.
      사진 : Contacts and nozzles
    1. Contacts
    2. Nozzles
  4. Hold the cartridge so that the nozzles are down and the contacts are facing the printer, and then slide the cartridge into the carriage.
    • Insert cartridges marked with a triangle into the left carriage slot.
    • Insert cartridges marked with a square or pentagon into the right carriage slot.
    사진 : Sliding the cartridge into the carriage
  5. Push the cartridge forward until it clicks into place.
    사진 : Pushing the cartridge into place
  6. Close the carriage access door.
    사진 : Closing the carriage access door
Step two: Align the cartridges
The product aligns the cartridges every time a cartridge is installed or replaced. Follow these steps to align the cartridges from the control panel:
  1. Make sure letter or A4 unused plain white paper is loaded in the input tray. Then press OK.
    사진 : Pressing the OK button
  2. The product prints a cartridge alignment sheet.
    주의:
    The alignment will fail if colored paper is loaded in the input tray. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Place the alignment sheet on the scanner glass for scanning.
  4. Press OK to begin the alignment.
  5. The product aligns the cartridges. Recycle or discard the cartridge alignment sheet.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
