조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP Photosmart D5060, D5063, D5065, and D5069 Printers - Installing Replacement Print Cartridges
This document explains how to install replacement print cartridges.
Replace the print cartridges
Use the following instructions to install replacement print cartridges.
Step one: Remove the print cartridges
  1. Make sure that the printer is on. If the Power button is not lit, press the Power button to turn on the printer.
    사진 : Power button
  2. Raise the Main printer cover.
    사진 : Raising the Main cover
  3. Pull the print cartridge that you want to replace out of its slot toward you.
    • The black print cartridge is located in the slot on the right.
    • The tri-color print cartridge is located in the slot on the left.
Step two: Install the new print cartridges
  1. Pull the pink tab to remove the clear tape from the first print cartridge.
    사진 : Removing the pink tab
      경고:
    Do not touch or remove the ink nozzles or copper-colored contacts.
    사진 : Do not touch ink nozzles or copper-colored contacts
  2. Hold the print cartridge so the copper-colored contacts go into the printer first, and then slide the cartridge into the appropriate slot. Push the cartridge firmly until it snaps in place.
    사진 : Inserting the print cartridge
      경고:
    To avoid print carriage jams, make sure the print cartridge snaps securely into place as you insert it.
    사진 : Snapping the print cartridge securely into place
  3. If replacing both print cartridges, repeat this process with the second print cartridge.
    주의:
    When installing print cartridges, use the symbols on the cartridge and cartridge slot to match up cartridge types.
  4. Lower the Main cover.
Step three: Align the print cartridges
If you are installing a new print cartridge, make sure that there is paper loaded in the tray, as the printer will automatically print a cartridge alignment page to confirm that the alignment was successful. This may take a few minutes.
Check marks on the alignment page verify that the print cartridge is installed correctly and functioning properly.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
