조치
로드 중...
HP 고객 지원 - 지식 기반
조치
로드 중...
조치
로드 중...
  • 정보
조치
로드 중...
HP Deskjet D2320, D2330, D2345, and D2360 Printers - Install or Replace the Print Cartridges
This document explains the basics of installing or replacing the print cartridges.
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover.
    사진 : Printer cover open
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    주의:
    HP recommends using a print cartridge protector to store an opened print cartridge for later use.
    사진 : Print cartridge being inserted into a print cartridge protector
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer.
    사진 : Removing the protective tape
      경고:
    Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
      사진 : Print cartridge facing up
    1. Ink nozzles
    2. Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place.
    사진 : Installing the print cartridge
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
조치
로드 중...
조치
로드 중...
조치
로드 중...
국가/지역: Flag 한국
조치
로드 중...
