    Dear Customer, HP remains committed to serve you even during the current pandemic situation by ensuring the continuity of our operations. Given the evolving Covid-19 situation in the country, you might experience some delay in delivering Onsite support to locations which are not accessible due to local Govt regulations. Thank You for your understanding and support.
    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP ENVY x360 Laptop - 13-ay0008ur Product Specifications
1L6D3EA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 SDRAM (onboard)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB (1920 x 1080)
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
1.32 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
Country/Region: Flag India
