Use the following as a quick reference to the printer control panel features.
Wireless light: Indicates the status of the printer wireless connection.Solid blue light indicates that wireless connection has been established and you can print.Slow blinking light indicates that wireless is on, but the printer is not connected to a network. Make sure your printer is within the range of wireless signal.Fast blinking light indicates wireless error. Refer to the message on the printer display.If wireless is turned off, the wireless light is off and the display screen shows Wireless Off.
Power button: Turns the printer on or off.
Back button: Returns to the previous screen.
Help button: Opens the Help menu for the current operation.
Home button: Returns to the Home screen, the screen that is displayed when you first turn on the printer.
Control panel display: Touch the screen to select menu options, or scroll through the menu items.
Figure : Graphic - The printer control panel
