תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP Business Desktop PCs - Updating the BIOS (Basic Input Output System)
This document is for HP business desktop computers.
Download and install updates to the computer BIOS. This process is also known as 'flashing the BIOS.'
  שים לב:
Only install BIOS updates from HP. Installing the BIOS incorrectly can prevent the computer from starting or being recovered. If your computer is managed by an IT service, contact them for the correct update process.
Updating the BIOS is recommended as standard maintenance of the computer. It can also help resolve the following issues:
  • An available BIOS update resolves a specific issue or improves computer performance.
  • The current BIOS does not support a hardware component or a Windows upgrade.
  • HP support recommends installing a specific BIOS update.
  שים לב:
Your company IT department or local IT service might manage BIOS settings. Confirm that the updated BIOS version is compatible with your company's deployment environment.
Choose to one of the methods in this document to update the BIOS.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
