תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
פעולות
טעינה...‏
HP OfficeJet Pro 7740 Printers - First Time Printer Setup
This document is for the HP OfficeJet Pro 7740 Wide Format All-in-One Printer.
To set up a printer for the first time, remove the printer from the box, remove packing materials, connect the power cable, set control panel preferences, install the ink cartridges, and then load paper into the input tray.
הערה:
If you are looking for the printer software, go to 123.hp.com/ojp7740 to download the print driver.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer, and then remove the film from the printer control panel.
    איור : Removing tape from the printer
  3. Lift the scanner lid, remove the packing material from the scanner glass, and then close the scanner lid.
    איור : Opening the scanner lid and removing packing material
Step 2: Connect the power cord and set your preferences
Plug the printer into an electrical outlet, turn on the printer, and then set your preferences.
הערה:
    איור : Connecting the power cord
  2. Turn on the printer.
  3. To set your preferences on the printer control panel, touch your preferred language and country/region, and then touch Yes to confirm your choices.
  4. Select the date and time, and then touch Yes to confirm.
Install the HP Setup ink cartridges that came in the box with your printer.
  1. Open the ink cartridge access door.
    איור : Opening the ink cartridge access door
    Opening the ink cartridge access door.
  2. Wait until the carriage is idle and silent before you proceed.
  3. Remove the plastic wrappers on the ink cartridges. Be careful to touch only the black plastic on the ink cartridge.
  4. Hold the ink cartridge by its sides with the color circle toward you, and then press the ink cartridge forward into its slot until it snaps into place.
    איור : Inserting the ink cartridges
    Inserting the ink cartridges.
  5. Install the other ink cartridges.
  6. Close the ink cartridge access door.
    איור : Closing the ink cartridge access door.
Step 4: Load paper into the input trays
Remove packing materials from the paper trays, and then load plain U.S. letter or A4 paper in the input trays.
  1. Pull out Tray 1, and then remove the packing materials.
    איור : Opening Tray 1, and then removing the packing material
    Opening the input tray
  2. Open the tray extension cover.
    איור : Opening the tray extension cover
  3. Load plain white paper with the short edge forward and the print side down.
      שים לב:
    Do not load more paper than indicated on the paper fill guide, or paper jams might occur.
    איור : Paper fill guide in the paper tray
    Paper fill guide in the input tray
  4. Push the stack into the tray until it stops.
  5. Slide in the paper guides in until they rest against the edges of the paper.
    איור : Sliding in the paper width guides
  6. Close the tray extender cover.
  7. Insert Tray 1 into the printer.
    איור : Inserting Tray 1
    Reinserting the input tray
    The printer aligns the printhead, and then an alignment page automatically prints.
  8. Wait until the printer is idle and silent before you continue.
  9. Repeat these steps for Tray 2.
  10. Recycle all packing materials.
Your HP printer hardware is now set up, and you can install the printing software.
Step 5: Install the printer software
Download the latest version of the printing software from 123.hp.com/ojp7740, and then follow the on-screen instructions to install the software.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
