תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
פעולות
טעינה...‏
HP LaserJet - Printers that can use HP Jetdirect print servers
HP Jetdirect print servers add wireless printing capability to compatible HP LaserJet printers in order to receive print jobs from a wireless-capable laptop, smartphone, or tablet.
This document provides a list of compatible HP printers that can use the following Jetdirect print servers:
הערה:
Click here to view information below about HP printers that can use the HP Jetdirect 300x model.
  • HP Jetdirect 620n Fast Ethernet Print Server
  • HP Jetdirect 635n Print Server
  • HP Jetdirect 640n Print Server
  • HP Jetdirect 695nw Print Server
  • HP Jetdirect ew2500 802.11b/g Wireless Print Server
  • HP 1284B Parallel Card
For information about Jetdirect models 3000w, 2900nw, 2800nw, or 2700, go to Printers that can use HP Jetdirect print servers and NFC/wireless accessories.
For information about the HP 1200w NFC/Wireless Accessory, go to Printers that can use the HP 1200w NFC/Wireless Mobile Print Accessory.
HP LaserJet Enterprise series
הערה:
Models indicated below with an asterisk (*) must update the firmware and firmware level in order to be compatible with the print server. For instructions, see Update the firmware.
ew2500
695nw
640n
635n
620n
1284B
HP LaserJet Enterprise 500 MFP M525*
HP LaserJet Enterprise flow MFP M525c*
HP LaserJet Enterprise 500 Color Printer M551*
HP LaserJet Enterprise 500 Color MFP M575*
HP LaserJet Enterprise color flow MFP M575c*
HP LaserJet Enterprise 600 Printer M601
HP LaserJet Enterprise 600 Printer M602*
HP LaserJet Enterprise 600 Printer M603*
HP LaserJet Enterprise MFP M630
HP Color LaserJet Enterprise M651 Printer
HP Color LaserJet Enterprise M680 Multifunction Printer
ew2500
695nw
640n
635n
620n
1284B
HP LaserJet Enterprise 700 M712*
HP LaserJet Enterprise 700 MFP M725*
HP Color LaserJet Enterprise M750 Printer
HP LaserJet Enterprise 700 Color MFP M775*
HP LaserJet Enterprise M806 Printer
HP LaserJet Enterprise flow M830 Multifunction Printer
HP Color LaserJet Enterprise M855
HP Color LaserJet Enterprise flow MFP M880
HP Color LaserJet Enterprise CM4540 MFP
HP LaserJet Enterprise M4555 MFP
HP Color LaserJet Enterprise CP5525 Printer
HP LaserJet Pro series
ew2500
695nw
640n
635n
620n
1284B
HP LaserJet Pro 300 M351 Printer
HP LaserJet Pro 400 M401 Printer
HP LaserJet Pro 400 M451 Printer
HP LaserJet series (older)
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP Color LaserJet CM1015/CM1017 MFP
HP Color LaserJet CP1025
HP LaserJet 1160
HP Color LaserJet CM1312 MFP
HP LaserJet 1320 Printer
HP Color LaserJet CP1510/CP1514/CP1515/CP1518 Printer
HP Color LaserJet CP1525 Printer
HP LaserJet P2010/P2014 Printer
HP LaserJet P2015 Printer
HP Color LaserJet CP2025 Printer
HP LaserJet P2035 Printer
HP LaserJet P2055 Printer
HP LaserJet 2200 Printer
HP LaserJet 2300 Printer
HP LaserJet 2400/2410/2420/2430 Printer
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP Color LaserJet 2500
HP Color LaserJet 2600n
HP Color LaserJet 2605
HP Color LaserJet 2700
HP Color LaserJet 3000 Printer
HP Color LaserJet P3005 Printer
HP LaserJet Enterprise P3015 Printer
HP LaserJet M3027 Multifunction Printer
HP LaserJet M3035 Multifunction Printer
HP Color LaserJet CP3505 Printer
HP Color LaserJet CP3520/CP3525 Printer
HP Color LaserJet CM3530 MFP
HP Color LaserJet 3600 Printer
HP Color LaserJet 3700 Printer
HP Color LaserJet 3800 Printer
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP LaserJet 4000 Printer
HP Color LaserJet CP4005 Printer
HP LaserJet P4014 Printer
HP LaserJet P4015 Printer
HP Color LaserJet Enterprise CP4025 Printer
HP LaserJet 4050 Printer
HP LaserJet 4100 Printer
HP LaserJet 4100 Multifunction Printer
HP LaserJet 4200 Printer
HP LaserJet 4240 Printer
HP LaserJet 4250 Printer
HP LaserJet 4300 Printer
HP LaserJet 4345 Multifunction Printer
HP LaserJet M4345 Multifunction Printer
HP LaserJet 4350 Printer
HP LaserJet 4500 Printer
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP LaserJet P4510/P4515 Printer
HP Color LaserJet Enterprise CP4525 Printer
HP LaserJet 4550 Printer
HP LaserJet 4600/4610 Printer
HP LaserJet 4650 Printer
HP LaserJet 4700 Printer
HP Color LaserJet 4730 Multifunction Printer
HP Color LaserJet CM4730 MFP
HP LaserJet 5000 Printer
HP LaserJet M5025 Multifunction Printer
HP LaserJet M5035 Multifunction Printer
HP LaserJet 5100 Printer
HP LaserJet 5200 Printer
HP LaserJet CP5225 Professional Printer
HP Color LaserJet 5500 Printer
HP Color LaserJet 5550 Printer
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP Color LaserJet CP6015 Printer
HP Color LaserJet CM6030/CM6040 MFP
HP LaserJet 8000 Printer
HP CM8000/CM8050/CM8060 Color MFP
HP LaserJet 8100 Printer
HP LaserJet 8150 Printer
HP Color LaserJet 8500 Printer
HP Color LaserJet 8550 Printer
HP LaserJet 8550 Multifunction Printer
HP LaserJet 9000 Printer
HP LaserJet 9000 Multifunction Printer
HP LaserJet 9040 Printer
HP LaserJet 9050 Printer
HP LaserJet 9040/9050 MFP
HP LaserJet M9040/M9050 MFP
HP Color LaserJet 9500 Printer
HP Color LaserJet 9500 Multifunction Printer
HP LaserJet All-in-One series (older)
HP LaserJet series
ew2500
695nw
640n
635n
620n
1284B
HP Color LaserJet 2800 All-in-One (2820/2840)
HP LaserJet 3050 All-in-One
HP LaserJet 3052 All-in-One
HP LaserJet 3055 All-in-One
HP LaserJet 3380 All-in-One
HP LaserJet 3390 All-in-One
HP LaserJet 3392 All-in-One
HP Jetdirect 300x supported printers
Any network-capable printer with an IEEE-1284 compliant parallel port and a compatible network driver from Windows Update can use the HP Jetdirect 300x model. The HP printer must support printing using the HP PCL, HP/GL-2, ASCII or PostScript printer languages. To make sure, print an HP Jetdirect Configuration Page.
הערה:
Parallel port connections are not supported in Windows 8 and newer. Use Windows 7.
Update the firmware
Step one: Update the printer firmware
To update the printer firmware for a print server, update the host HP LaserJet printer's firmware using one of the following methods:
  • USB
  • Web Jetadmin
Step two: Change the printer firmware level to HP FutureSmart level 3
To set the printer firmware to HP FutureSmart level 3, use the printer's Embedded Web Server (EWS):
הערה:
For information about changing the HP FutureSmart setting using the latest version of HP Web Jetadmin, go to www.hp.com/go/wja and click the Self Help and Documentation tab.
  1. From the Home screen on the printer control panel, touch the network button to display the printer's IP address or host name.
  2. Open a Web browser, and in the address field, type the IP address or host name exactly as it displays on the control panel, and then press Enter.
  3. Click the General tab and then click Firmware Upgrade from the left menu pane.
  4. In the Change HP FutureSmart Level section, select HP FutureSmart 3 from the drop-down list, click Change. The accessory or print server will be recognized after the printer reboots.
More information
For more setup, configuration, or troubleshooting information, go to one of the following links:
For more information about your HP Jetdirect model, go to www.hp.com/support, click Troubleshooting, search for your model number, and then click the Manuals tab, or click the Troubleshooting tab and under Other solution options, click Troubleshoot a problem to view more web topics for that model.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
