תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • משוב
פעולות
טעינה...‏
HP printers - Print with Mopria Print Service (Android)
Seamlessly print from an HP Mopria certified printer using the Mopria Print Service. The Mopria Print Service enhances printer functionality on an Android smartphone or tablet without any additional setup.
Print with the Mopria Print Service
Print photos, documents, emails, or web pages from your mobile device.
  1. Make sure your printer and mobile device are ready to print.
    • The printer is connected to a network or has Wi-Fi Direct turned on.
    • Your mobile device and printer are connected to the same network and within 1.8 m (6 ft) of the router.
    • Android 7 (Nougat) or earlier: The Mopria Print Service app (in English) is installed and enabled in the device Settings menu.
  2. On your mobile device, open the item you want to print.
  3. Tap the Menu icon , and then tap Print.
  4. Select the name of your printer.
  5. Tap the down arrow , and then change any desired print settings, such as page range, borders, or print quality.
  6. Tap the Print icon .
For more information, go to Mopria - Print from Android (in English).
Refer to these frequently asked questions for more information about the Mopria Print Service for Android devices.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
