This document is for HP Officejet 6812, 6815, 6820, Officejet Pro 6830, and 6835 e-All-in-One printers.
Complete the steps in this document to set up the printer hardware before you install the printer software on the computer.
שים לב:Do not fill the paper higher than the yellow, dotted lines on the sides of the paper tray.
שים לב:Do not connect a USB cable at this time. The printer prompts you to connect the USB during the software installation.
שים לב:Failure to install the SETUP cartridges that came with the printer causes a cartridge error.
שים לב:Make sure that you remove the orange pull-tab and plastic wrap completely before you remove the orange cap in the next step. Otherwise, ink might leak from the cartridge. When you remove the plastic wrap, the paper label on the top of the cartridge tears slightly, which is necessary to properly vent the cartridge.
שים לב:Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
