תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP LaserJet Pro Printers - Replacing the Toner Cartridge
This document is for the following printers.
HP LaserJet Pro MFP M125a
HP LaserJet Pro MFP M127fs
HP LaserJet Pro MFP M125nw
HP LaserJet Pro MFP M127fw
HP LaserJet Pro MFP M125r
HP LaserJet Pro MFP M128fn
HP LaserJet Pro MFP M125ra
HP LaserJet Pro MFP M128fp
HP LaserJet Pro MFP M125rnw
HP LaserJet Pro MFP M128fw
HP LaserJet Pro MFP M126a
HP LaserJet Pro MFP M26a
HP LaserJet Pro MFP M126nw
HP LaserJet Pro MFP M26nw
HP LaserJet Pro MFP M127fn
Replace the toner cartridge when one of the following messages displays:
  • HP LaserJet Pro MFP M26a printers: An E0 message displays and the Attention light blinks on the printer control panel.
  • HP LaserJet Pro MFP M26nw, M125a, M125nw, M125r, M125ra, M125rnw, M126a, M126nw, M127fn, M127fs, M127fw, M128fn, M128fp, M128fw printers: A Cartridge is Low or a Cartridge is Very Low message displays on the printer control panel.
To replace the toner cartridge, open the scanner assembly and top cover, remove the old toner cartridge, and then install a new one.
  1. Lift the scanner assembly.
    איור : Lifting the scanner assembly
    Lifting the scanner assembly.
  2. Open the top cover.
    איור : Opening the top cover
    Opening the top cover.
  3. Remove the toner cartridge.
    איור : Removing the toner cartridge
    Removing the toner cartridge.
  4. Remove the new toner cartridge from the package.
    איור : Removing the new toner cartridge from the package
    Removing the new toner cartridge from the package.
  5. Place the used toner cartridge in the bag for recycling.
  6. Locate the orange clip on the new toner cartridge.
      איור : Locating the orange clip on the new toner cartridge
      Locating the orange tabs on the toner cartridge.
    1. The orange clip
    2. The orange tab with sealing tape
  7. Remove the orange clip by pulling upward.
    איור : Removing the orange clip
    Removing the orange clip from the toner cartridge.
  8. Grasp both sides of the toner cartridge, and then distribute the toner by gently rocking the toner cartridge back and forth.
      שים לב:
    Do not touch the shutter or the surface of the roller.
    איור : Gently rocking the toner cartridge
    Gently rocking the toner cartridge.
  9. Bend the tab on the left side of the toner cartridge until the tab breaks loose. Pull the tab until all the sealing tape is removed from the toner cartridge.
    איור : Removing the sealing tape
    Removing the sealing tape.
  10. Place the tab and tape in the toner cartridge box to return for recycling.
  11. Align the new toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
    איור : Installing the toner cartridge
    Installing  the toner cartridge.
  12. Close the top cover.
    איור : Closing the top cover
    Closing the top cover.
  13. Lower the scanner assembly.
    איור : Lowering the scanner assembly
    Lowering the scanner assembly.
Review the list of frequently asked questions about replacing toner cartridges.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
