This document is for HP LaserJet Pro MFP M125a, M125nw, M125r, M125rnw, M126a, M126nw
printers.
- ${title}
טעינה...
תמיכת הלקוחות של HP - מאגר ידע
- ${title}
טעינה...
- ${title}
טעינה...
- ${title}
טעינה...
HP LaserJet Pro Printers - Setting Up the Printer Hardware
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Step 2: Remove the packaging and prepare the cartridge
Follow these steps to remove all the packaging material from the printer and then prepare the cartridge for printing.
Take the printer out of its box, and then remove the packaging.איור : Unpack the printer
Put the printer on a sturdy table in a well-ventilated, dust-free place, away from direct sunlight.
Remove the packing tape from the printer.איור : Remove the packing tape from the printer
Open the scanner assembly, and then open the top cover.איור : Open the scanner assembly, and then open the top cover
Remove the protective foam from the cartridge access area, and then set it aside for recycling.איור : Remove the protective foam
Remove the toner cartridge, and then set it aside in a secure place.איור : Remove the toner cartridge
Remove packaging from inside the printer, and then set it aside for recycling.איור : Remove packaging from inside the printer
Grasp both sides of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.איור : Gently rock toner cartridge
Remove the orange clip from the toner cartridge, and then set it aside for recycling.איור : Remove the orange clip from the toner cartridge
Pull the orange tab to remove the sealing tape from the toner cartridge, and then set it aside for recycling.איור : Remove the sealing tape from the toner cartridge
Align the toner cartridge with the tracks inside the printer, and then insert the toner cartridge until it is firmly seated.איור : Insert the print cartridge
Close the top cover, and then close the scanner assembly.
Step 3: Load paper
Follow these steps to load paper in the paper input tray.
Attach the input paper tray to the printer.איור : Attach the input paper tray to the printer
Slide the paper guides to their outermost positions.איור : Slide the paper guides out
Load a stack of U.S. letter or A4 size paper into the input tray with the short edge forward and the print side up. Push the stack into the tray until it stops.איור : Load paper into the input tray
Slide in the paper guides until they rest against the edges of the paper.
הערה:
Do not push the paper guides so far in that they bind the paper.איור : Slide the paper guides in
Step 4: Connect the power cord and turn on the power
Connect the power cord to the rear of the printer.
Plug the power cord into an electrical outlet.איור : Connect the power cord
Press the Power button to turn on the printer. The printer initializes and calibrates itself.
הערה:
Wait until the printer is idle and silent before proceeding.
Step 5: Select the language
Follow these steps to select the language displayed on the printer control panel.
On the printer's control panel, press the Setup (
) button.
Press the Right Arrow (
) until System Setup displays, and then press OK.
Touch Language, and then if necessary, press the Right Arrow (
) to find your desired language in the list.
Touch your desired language.
הערה:
If you selected the wrong language, repeat these steps.
אפשרויות תמיכה נוספות
- ${title}
טעינה...
- ${title}
טעינה...
- ${title}
טעינה...
מדינה/אזור:
ישראל
- ${title}
טעינה...
hp-hero-support-search
- ${title}
טעינה...
