תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP Officejet 4630, Deskjet 4640 Printers - First Time Printer Setup
This document is for the following printers:
HP Deskjet Ink Advantage 4645 e-All-in-One Printer
HP Officejet 4632 e-All-in-One Printer
HP Deskjet Ink Advantage 4646 e-All-in-One Printer
HP Officejet 4634 e-All-in-One Printer
HP Deskjet Ink Advantage 4648 e-All-in-One Printer
HP Officejet 4635 e-All-in-One Printer
HP Officejet 4630 e-All-in-One Printer
HP Officejet 4636 e-All-in-One Printer
HP Officejet 4631 e-All-in-One Printer
HP Officejet 4639 e-All-in-One Printer
To set up a printer for the first time, unpack the printer, connect the power cable, set your preferences, load paper into the input tray, and then install the ink cartridges.
הערה:
If you are looking for the printer software, go to:
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the front and rear of the printer.
  3. Raise the scanner lid, and then remove the packing tape.
    איור : Removing the packing tape from under the scanner lid
    Image: Remove the packing tape from under the scanner lid
  4. Lower the scanner lid.
  5. Gently grasp the handles on either side of the printer, raise the ink cartridge access door until it locks into place, and then remove all tape and packing material from inside the printer.
      איור : Removing the tape and packing materials from inside the printer
      Image: Removing the tape and packing material from inside the printer.
    1. Open the ink cartridge access door
    2. Remove the tape and packing material from the cleanout area
    3. Remove the tape and packing material from the ink cartridge access area
  6. Close the ink cartridge access door.
    איור : Closing the ink cartridge access door
    Image: Close the ink cartridge access door.
  7. Open the paper tray door, pull it toward you to extend the paper tray, and then remove the packing tape.
    איור : Removing the packing tape from the paper tray
    Image: Removing the packing tape from the paper tray.
  8. Push the paper tray forward until it clicks into place, and then close the paper tray door.
  9. Recycle the packing materials.
    איור : Recycling the packing materials
    Image: Recycling the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into a power source, turn on the printer, and then set your preferences.
הערה:
  1. Connect the power cord to the rear of the printer, and then plug it into a wall outlet.
    איור : Connecting the power cord
    Image: Connecting the power cord.
  2. Turn on the printer.
    איור : Turning on the printer
    Image: Turning on the printer.
  3. On the printer control panel, press the down arrow to select the language, and then press OK.
    איור : Selecting your language and country/region
    Image: Select your language and country/region.
  4. Press the down arrow to select Yes, and then press OK.
    The Set Country/Region menu opens.
  5. Press the down arrow to select the country/region, and then press OK.
  6. Press the down arrow to select Yes, and then press OK.
Step 3: Load paper into the input tray
Load plain, U.S. letter, or A4 paper in the input tray.
  1. Open the input tray door, and then pull it toward you to extend the input tray.
  2. Gently pull out the input tray extender, and then lift the paper catch.
    Image: Pulling out the  input tray and  tray extender.
  3. Slide the paper width guides to their outermost position.
    Image: Adjusting the paper width guides.
  4. Load a stack of U.S. letter, or A4 size paper into the paper tray with the short edge forward and the print side down.
    Image: Loading paper in the input tray.
  5. Push the stack into the tray until it stops.
  6. Slide in the paper width guides until they rest against the edges of the paper.
    Image: Sliding in the paper width guides.
  7. Push the input tray forward until it clicks into place.
    הערה:
    Push the input tray forward all the way to avoid an error message.
    Image: Push the input tray forward until  it clicks into place.
Step 4: Install the ink cartridges
Install HP ink cartridges.
  1. Grasp the handles on either side of the ink cartridge access door, and then raise the ink cartridge access door until it locks into place.
    איור : Opening the ink cartridge access door
    Image: Opening the ink cartridge access door.
  2. Wait until the carriage is idle and silent before you proceed.
  3. Remove one of the ink cartridges from its package. Be careful to only touch the black plastic on the ink cartridge.
    איור : Removing the ink cartridge from its package
    Image: Removing the ink cartridge from its package.
  4. Remove the plastic tape from the ink cartridge.
      שים לב:
    איור : Removing the plastic tape
    Image: Removing the plastic tape
  5. Lift up the lid on the ink cartridge slot.
    איור : Lifting up the lid on the ink cartridge slot
    Image: Lifting up the lid on the ink cartridge slot
  6. Hold the ink cartridge by its sides with the nozzles toward the printer, then press the ink cartridge forward into the slot until it snaps into place.
    איור : Inserting the ink cartridge
    Image: Inserting the ink cartridge.
  7. Close the lid on the ink cartridge slot to secure the ink cartridge into place.
    איור : Closing the lid on the ink cartridge slot
    Image: Closing the lid on the ink cartridge slot
  8. Repeat the previous steps to install the other ink cartridge.
      איור : Inserting the ink cartridges
      Image: Inserting the ink cartridges
    1. Insert the ink cartridge
    2. Close the lid
    3. The color ink cartridge is on the left, and the black ink cartridge is on the right
  9. Close the ink cartridge access door.
  10. Follow the instructions on the control panel to start the ink cartridge alignment.
    The printer aligns the ink cartridges and prints an alignment page.
Step 5: Install the printer software
Download the latest version of the printing software from the following HP websites:
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
