תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
פעולות
טעינה...‏
Setting Up the Printer Hardware for HP Deskjet 1010 and HP Deskjet Ink Advantage 1010 Printer Series
This document explains how to set up your printer hardware.
Important: You must follow these steps in the order presented to set up your printer correctly. Do not connect the USB cable until instructed to do so.
Video of setting up the printer
The following video demonstrates how to set up the physical parts of the printer.
הערה:
This video shows the HP Deskjet 1010 printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Step one: Unpack the printer
  1. Remove the tape and packing material from the outside of the printer.
  2. Open the output tray, and then open the cartridge access door.
    איור : Open the output tray and cartridge access door
    Image: Open the output tray and cartridge access door
  3. Remove the tape and cardboard from inside the printer
    איור : Remove the packing materials from inside the printer
    Image: Remove the packing materials from inside the printer.
  4. Close the cartridge access door.
    איור : Close the cartridge access door
    Image: Close the cartridge access door.
Step three: Connect the power cord and adapter
  1. Connect the adapter cord to the rear of the printer.
  2. Connect the power cord to the power adapter, and then plug the power cord into an electrical outlet.
      איור : Connect the power cord
      Image: Connect the power cord.
    1. Connect the cord from the adapter to the rear of the printer
    2. Connect the power cord to the adapter
    3. Plug the power cord into the electrical outlet
Step four: Turn on the power
Press the Power button to turn on the printer.
איור : Turn on the printer
Image: Turn on the printer.
Step five: Install the cartridges
  1. Lower the output tray, and then open the cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before you continue.
    איור : Open the output tray and the cartridge access door
  2. Remove the new cartridge from its package, and then carefully pull on the orange tab to remove the protective plastic tape.
      שים לב:
    Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
    איור : Remove the protective tape
    Image: Remove the protective tape
  3. Hold the cartridge by its sides with the nozzles toward the printer, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
    • The tri-color cartridge () goes in the slot on the left
    • The black cartridge () goes in the slot on the right
    איור : Insert the cartridge into its slot
    Image: Inserting the cartridge
  4. Push the cartridge forward into its slot until it snaps into place.
    איור : Push the cartridge forward
    Image: Push the cartridge forward
  5. Repeat these steps to install the other cartridge.
    איור : Install the second cartridge
    Image: install the other cartridge
  6. Close the cartridge access door.
Step six: Load plain paper
Follow these steps to load plain paper into the printer.
  1. Lift the paper tray.
    איור : Lift the paper tray
    Image: Lift the paper tray
  2. Lower the output tray, and then pull out the output tray extender.
    איור : Pull out the tray extender
    Image: Pull out the output tray extender
  3. Slide the paper width guide to its outermost position.
  4. Load clean, white paper in the input tray with the short edge forward and the print side up.
    איור : Load the paper
    Image: Load the paper
  5. Slide the paper width guide to the right until it stops at the edge of the paper but does not bend the paper.
    איור : Slide the paper width guide against the paper
    Image: Slide the paper width guide against the paper
Step seven: Align the cartridges
After you install the cartridges, follow the steps for your operating system to align the cartridges. If you do not align the cartridges now, the printer prompts you to do so the next time you try to print.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
