This document is for HP Photosmart 7520 and 7525 e-All-in-One printers.
To set up a printer for the first time, unpack the printer, connect the power cable, set your preferences, load paper in the main input tray, and then install the ink cartridges.
הערה:If you are looking for the printer software, go to http://123.hp.com/PS7520.
