- ${title}
טעינה...
תמיכת הלקוחות של HP - מאגר ידע
- ${title}
טעינה...
- ${title}
טעינה...
- ${title}
טעינה...
HP LaserJet Pro M1536dnf, M1537dnf, M1538dnf, and M1539dnf Multi-Function Printers - Setting Up the LaserJet (Hardware)
Unpack the product
Check the contents of the box
Remove packing tape and attach trays
Insert the cartridge
Connect the power cord
Turn on the power
Select the language
Load plain paper
Setting up the product
הערה:Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Step one: Unpack the product
Remove the product and other items from the box.
איור : Unpack the product
Step three: Remove the tape and packing material from the product
Position the product on a sturdy surface in a well-ventilated, dust-free area that is away from direct sunlight.
Remove all pieces of blue tape from the product.איור : Remove tape from the product
Open the cartridge door.
Lift up the paper packing material, but do not remove it.איור : Lift up the paper packing material
Remove the cartridge packing material.איור : Remove the cartridge packing material
Remove the cartridge from the product.איור : Remove the cartridge
שים לב:
Hold the cartridge at each end to prevent damage to the cartridge. -
Remove the paper packing material from inside the product.איור : Remove the paper packing material
Step four: Attach the trays
Attach the output tray by snapping it into place.איור : Attach the output tray
Attach the priority input tray.איור : Attach the priority input tray
Step five: Prepare and insert the cartridge
Open the print cartridge door.איור : Open the print cartridge door
Remove the orange clip from the end of the cartridge.איור : Remove the orange clip
Gently rock the cartridge from front to back to distribute the toner.איור : Rock the cartridge
Remove the sealing tape from the cartridge.
Bend the tab on the left side of the cartridge until the tab breaks loose.
Pull the tab to remove the sealing tape from the cartridge.
Put the tab in the cartridge box to return for recycling.
איור : Remove the sealing tapeשים לב:
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric. -
Insert the cartridge into the product, and then close the cartridge door.איור : Insert the cartridge and then close the door
Step six: Connect the power cord
Connect the power cord to the rear of the product, and then plug it into a wall outlet.
איור : Connect the power cord
Step seven: Turn on the power
Press the Power button (
) to turn on the product.
איור : Turn on the product
הערה:After you turn on the product, an 'Install black cartridge' message might display on the product control panel. If you receive this message, follow these steps to resolve the issue.
Step eight: Select the language
On the control panel, press the Setup button (
Press the Right Arrow (
) to select System Setup, and the press OK.
Press OK to select Language.
) to select your language, and then press OK.
Press OK to confirm the selection.
Step nine: Load plain paper
Slide the paper width and length guides to their outermost positions.
Place a stack of paper in the tray, and then make sure that it is flat at all four corners.איור : Load plain paper into Tray 1
Slide the paper guides in so that they rest against the stack of paper.איור : Slide the paper guides in
אפשרויות תמיכה נוספות
- ${title}
טעינה...
- ${title}
טעינה...
- ${title}
טעינה...
מדינה/אזור:
ישראל
- ${title}
טעינה...
hp-hero-support-search
- ${title}
טעינה...
