תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP LaserJet Pro Printers - Setting Up Printer Hardware
This document is for the LaserJet Pro P1102, P1102s, P1102w, P1106, P1108, P1109, and P1109w printers.
This document includes the following steps to set up the printer:
  • Remove packing tape
  • Prepare the print cartridge
  • Load plain paper
  • Turn on power
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Remove the printer from the box, and then check the contents of the box.
Step 2: Remove packing tape
Remove all packing tape from the printer.
Step 3: Prepare the print cartridge
  1. Open the print cartridge door.
    איור : Open the print cartridge door
    Illustration: Open the print cartridge door.
  2. Remove the print cartridge packaging.
    איור : Remove the print cartridge packaging
    Illustration: Remove the print cartridge packaging.
  3. Remove the print cartridge from the printer.
    Illustration: Remove the print cartridge.
      שים לב:
    To prevent damage to the print cartridge, hold the print cartridge at each end.
  4. Remove the packaging from inside the printer.
    איור : Remove the packaging from inside the printer.
    Illustration: Remove the packaging from inside the printer.
  5. Remove the orange clip from the end of the print cartridge.
    איור : Remove the orange clip from the print cartridge
    Illustration: Remove the orange clip from the print cartridge.
  6. Gently rock the print cartridge back and forth to distribute the toner evenly.
    איור : Rock the print cartridge
    Illustration: Rock the print cartridge.
  7. Bend the tab on the left side of the print cartridge until the tab breaks loose, and then pull the tab to remove all the sealing tape from the print cartridge.
    איור : Remove the sealing tape
    Illustration: Remove the sealing tape.
      שים לב:
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  8. Insert the print cartridge, and then close the print cartridge door.
    איור : Insert the print cartridge and close the door
    Illustration: Insert the print cartridge and close the door.
Step 4: Load plain paper
To load plain paper in the main input tray, follow these steps.
  1. Slide the paper length and width guides to their outermost positions.
    איור : Slide out paper guides
    Illustration: Slide out paper guides.
  2. Load plain paper in the main input tray with the top forward and the print side up.
    איור : Load paper
    Illustration: Load paper into the main input tray.
  3. Slide the paper guides inward so that they rest against the stack of paper.
    הערה:
    To prevent jams and skewing, always adjust the side and front paper guides.
    איור : Adjust the paper guides
    Illustration: Adjust the paper guides
Step 5: Turn on power
  1. Connect the power cord to the back of the printer.
    איור : Connect the power cord
    Illustration: Connect the power cord to back of printer
  2. Plug the power cord into an electrical outlet.
  3. Press the Power button to turn on the printer.
    איור : Turn on the power
    Illustration: Turn on the power.
    הערה:
    A blank page might print when you turn on the printer for the first time.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
