תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
פעולות
טעינה...‏
Replacing Cartridges for HP Deskjet 5100 Color Inkjet Printer Series
This document explains how to replace the cartridges.
Replacing cartridges
Follow these steps in the order given to install a replacement cartridge.
Step one: Prepare the cartridge
Remove the cartridge from its packaging and carefully remove the plastic tape.
איור : Removing the plastic tape
  שים לב:
Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
איור : Do not touch the nozzles or contacts
Step two: Replace the old cartridge
הערה:
The following graphics show the tri-color cartridge being replaced in the left carriage slot. If you replace the black cartridge, use the right carriage slot.
  1. Open the printer lid and wait for the carriage to move to the middle of the printer.
  2. When the carriage is idle and silent, lift the cartridge latch to the open position.
    איור : Lift the cartridge latch
  3. Slide the old cartridge out of its slot.
    איור : Slide the old cartridge out
  4. Insert the new cartridge into the slot at a slightly upward angle with the copper contacts facing down and toward the printer.
    איור : Insert the new cartridge
  5. Press firmly until the cartridge clicks into place.
  6. Push down on the cartridge latch until it snaps shut.
  7. Close the top cover. The product automatically prints a calibration page.
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
