תמיכת הלקוחות של HP - מאגר ידע
פעולות
טעינה...‏
פעולות
טעינה...‏
  • מידע
    למד כיצד לשדרג ל- Windows 11
    ניתן למצוא שאלות נפוצות ותשובות כאן
  • משוב
פעולות
טעינה...‏
HP Deskjet D4360, D4363, and D4368 Printers - Replacing Ink Cartridges
This document is for HP Deskjet D4360, D4363, and D4368 printers.
To prevent print quality issues, replace the ink cartridges when they are low or out of ink.
  1. Make sure the printer is turned on. If necessary, press the Power button () to turn the printer on.
  2. Open the top cover of the printer.
    איור : Opening the top cover
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage.
    איור : Removing the ink cartridge
    • To replace the tri-color ink cartridge, remove the ink cartridge from the left slot.
    • To replace the black ink cartridge, remove the ink cartridge from the right slot.
  5. Remove the new ink cartridge from its packaging and pull the pink tab to remove the protective tape from the ink cartridge.
    איור : Removing the protective tape
      שים לב:
    Do not touch the ink nozzles or copper contacts on the ink cartridge. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    1. Ink nozzles (do not touch)
    2. Copper contacts (do not touch)
  6. Hold the ink cartridge so that the copper strips are on the bottom and facing toward the printer.
  7. Slide the ink cartridge at a slight upward angle into the carriage until the ink cartridge snaps into place.
    איור : Inserting the ink cartridge
    • The tri-color ink cartridge is installed on the left side of the carriage.
    • The black ink cartridge is installed on the right side of the carriage.
  8. Close the top cover.
    איור : Closing the top cover
פעולות
טעינה...‏
פעולות
טעינה...‏
מדינה/אזור: Flag ישראל
פעולות
טעינה...‏
